Question about Samsung Televison & Video
Samsung UN40D6000SFXZA has vertical white lines that are in front of the video image. What needs to be repaired?
JoeO700
  • 80 Answers
SOURCE: Vertical lines on screen when viewing
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
Posted on Feb 12, 2007
SOURCE: Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Posted on Oct 18, 2007
SOURCE: White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Posted on Mar 06, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
projdoc
  • 2237 Answers
SOURCE: dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Posted on Sep 02, 2009
I have a thin white vertical line in the center of my Samsung Plasma SP-P4231. It is in front of the menu. It appears as soon as I hit the power button and stays on for the duration.
I know nothing about flat panel tv sets but in earlier times a thin vertical white line meant a fault in the line - the line oscillator or the line amplifier and an outside chance of a fault in the synch. circuitry.
It would probably need an oscilloscope and some experience to find the exact source.
Nov 17, 2017 | Samsung Televison & Video
Samsung UN40D6000SFXZA TV has blue screen with vertical lines of various shades of blue.
You may try a new T-CON, but most of the problem could be a display panel.
Nov 01, 2017 | Samsung Televison & Video
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
TV has recently began displaying 2 images slightly offset from each other with lines. I absolutely love this tv plz help!
you have a digital problem..ive narrowed it down to 2 boards..the Main Bd..and the Tcon board..here are the purchasing details
http://www.shopjimmy.com/samsung-bn95-00496b-t-con-board.htm
http://www.shopjimmy.com/samsung-bn94-05038b-main-board-for-un40d6000sfxza.htm
looks like the main board is on backorder..id replace that first..its most suspect..lemme know how it goes
Feb 14, 2014 | Samsung Un40d6000sf 40" 1080p Hd Led Lcd...
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Vertical colored lines on white background on SyncMaster 740N
Hey dont open the LCD in a hurry......the problem may be due 2 usage of LCD 4 long time better dont on the pc for a day........or in night time keep it under the fan.......this may give a better result........
Nov 09, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung not working
NO THIS IS A INTERNAL RIBBON INSIDE.. PLEASE CONTACT ME KNDCHANEY@DEJAZZD.COM
I CAN FURTHER ASSIST YOU
Feb 02, 2009 | Samsung Compact MiniDV Digital Camcorder
Picture problem
THIS SOUNDS LIKE THE CCD.. YOU CAN PLAY OLD TAPES BACK CORRECTLY.. BUT WHEN U TRY TO RECORD THE IMAGE IS DISTORTED. LET ME NO IF THIS HELPS YOU..
Nov 21, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
