Question about Proscan Televison & Video
I have a Proscan 42 LED UHD TV and only get a white screen when I turn it on
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
SOURCE: tv wont turn on green led on but no life in the
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Posted on Mar 26, 2010
  • 11361 Answers
SOURCE: I have a 42" Proscan
That sounds like either bad T-CON board or main board, need real in-depth troubleshooting.
You can the parts here:
I hope it is still under warranty.
Failed TV and Monitors:
Learn about bad caps:
Posted on Dec 30, 2010
  • 74999 Answers
SOURCE: lg 42 inch lcd tv white screen
The digital processor board has the fault. Checking this baord, and repairing it is a very skilled work, and an experienced service technician only can do this.
Posted on Feb 27, 2012
  • 8617 Answers
SOURCE: Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from
Posted on Mar 03, 2012
I try to turn my proscan tv on and the the power comes on but before anything the tv blinks a d it turns off immediately, any advice?
About 51,900 results (0.55 seconds) Search Results
    My Proscan 42 tv is turning on and off by itself, changing ... > Manage My Life > Questions
    Oct 16, 2012 - My Proscan 42 tv is turning on and off by itself, changing channels on it's ... that is next to the power connection plug is discolored at the board.
    Proscan/RCA 123882 Power Supply Unit (PSU) Boards ...
    ? 2:48
    Jan 17, 2013 - Uploaded by
    RCA TV Repair for Blank Screen TV Will Not Power On How to fix... I have a Proscan PLDED3273A-E. Looks like my problem is the L1 (brown spot on board) - any suggestions? ... before it turns off the audio still works and the image still comes out if I ...Recently I tried turning it on and I get no standby light.
Jan 25, 2016 | Proscan Televison & Video
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
Proscan 42" LED 120hz TV no audio out except with hdmi
Look for the setup menu on the TV. It is common that you need to select either TV speakers or external speakers as only one will work at a time. If you want the sound to come out the audio output, you may need to select this option. Worth checking.
Dec 08, 2017 | Televison & Video
No screen proscan 42la30h
Lcd/Backlight! Main Problem On the led,lcd is the Bad lcd ribbon or Bord, Try turning off all the lights and Turning it on, then kneel down to the ground and see if u can see Channels changing when u click up/dwn or volume or even the Fuzzy look when theres no cable going to it. if u can see then its probably a bad board or chip.
Hope This Helps :)
Mar 08, 2012 | Proscan 42LA30H 42 in. LCD Television
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
My proscan TV was working fine. then the video went and now no audio.. it lights up briefly when u turn on. then screen goes dark.. is this fixable or better to get a new tv..It is only 3 years old
I believe it's fixable! Take a look on your video and audio cables (behind the TV, the red, yellow and white ones). They must have a problem. Already happened to me!
I hope I've helped...
Feb 14, 2011 | Proscan 42LA45H 42 in. LCD TV
Our Proscan 42 inch LED TV (only one month old) just started going fuzzy. There are green horizontal lines going across the entire screen. If I reset the TV (turn off and unplug) for a minute or so, then...
Possible fault in the convergence circuit, failure of the IC. I advice that you must not tamper on the TV but ask for the warranty replacement without even opening the set. You are entitled to this service and must not throw it off. So call up the dealership and register your complaint .
Sep 01, 2010 | Proscan Televison & Video
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Televison & Video Logo
37 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
