Question about Plumbing
The water well water pump does not stop by itself.
    Top Expert:
  • 49,235 Answers
Pressure switches do fail
Posted on Dec 13, 2016
How can check my water pump
How to Tell if a Car Water Pump Is Bad - YouTube
? 2:16
Jul 8, 2009 - Uploaded by eHow
If a car's water pump is bad, the pump will usually leak, the engine compartment ... then the car shut off on the highway and a break stopped working I had to use the .... I need to know whymy water pump housing itself is rusty.
Nov 06, 2015 | Cars & Trucks
Toyota repair
check for a loose electrical connection or a faulty stop solenoid on the pump or injector controls if common rail . It sound that the stop control has an intermittent continuity problem ( broken wire-dirty connection---bad earth site etc)
Dec 21, 2013 | Cars & Trucks
2002 gmc truck water pump making noise how to stop noise
Gday mate, geoff here, could be the belt mate, try a bit wd40 / rp7 / crc, on the belt just a quick squirt or rub some soap on the V of the belt ,if noise persists could be the pump itself worn, does it have any lateral or dynamic play when wiggled, while engine off of course, hope this helps , geoff.
Feb 11, 2012 | GMC Sierra 1500 Cars & Trucks
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
Washer won't drain or spin
you need to check the water pump... it may be clogged with detergent or something to that effect.. or just replace the pump itself..
Oct 11, 2009 | Washing Machines
Waterpump leaks
Maybe. You could put an additive in, at the radiator cap, but there is no saying it will stop the leak. Are you sure it's the gasket and not the water pump itself. It has abuilt in leak to let you know it's wearing out. Check under the water pump and see if your coolant is coming out of the small hole on the bottom of the pump. If it is change the pump.
Aug 01, 2009 | 1992 GMC Jimmy
8hp yamaha runs hot
In most outboards, it will flow through the prop itself (through the inner prop). There should be a stream of water coming from somewhere around the back end of the motor itself, called a telltale, which visually shows that the water pump inside the outboard is pumping water up around the motor. If you cannot see this, then there is obviously a problem with the water pump or pump impeller that needs to be corrected to prevent the outboard overheating.
Jul 04, 2009 | Light Outboard Motor Boat Bass Fishing...
Water pump turns on and runs for a short time than stops for a short time then starts and then stops. And the machine can not spin because the water is not out enough.
Check the pulley, the belt(s) that turns the pulley and water pump, and check the water pump itself. Also, check for debris in the hose from the tub to the water pump,
Jun 18, 2008 | Hotpoint Washing Machines
Plumbing Logo
233 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
