Question about Dyson Vacuums
My Dyson DC 40 will not stay on? How do I fix it?
I have cleaned every filter I can find and I have cleaned the roller on the bottom. If I hold the on button down, the suction is good but it will not stay on. How do I fix it?
    Top Expert:
  • Dyson Master
  • 8,213 Answers
This is all i could find,try this link..
http://www.repairmydyson.com/no-power
Posted on Dec 13, 2016
Testimonial: "That link did not have a helpful solution for my dyson"
  • NOEL
    NOEL Dec 13, 2016
    it sounds like the on and off switch is faulty may need replacing or if you know how to open it to get to the switch to have a look and see why this is happening or get someone that could have a look at it for you.
Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
How do you change the belt
on the bottom of the vacume you should see about 4 screws ( philips ) that hold the plate in place, remove the screws and plate and this will expose the motor shaft,belt and roller ( you should also see the broken belt there two ) -- pop out the roller ( pull straight up ). put new belt onto the motorspindle and then onto the roller, snap roller back into place ( note: on the edges of the roller it is somewhat keyed to only fit into the vacume a certain way ), replace the the plate and screws and you are good to go. also while you are getting dirty -- clean the air filter and examine the hose between the floor roller and the suction hose for dirt build up and debris.
c...
Jan 01, 2011 | Dirt Devil M086700 Vision Bagless Upright...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Progressive with Direct Drive not picking up
check and see if your brush roller is turning.remove the hose and see if you have suction.if not then you have something stuck in the suction intake. after removing the hose turn it on and put your hand over the hole wher the hose was connected to the base.if there is suction there then you have a blockage in your hose.if thats the case take the hose completely off the vacuum and take it outside and blow it out with a garden hose.if the blockage is in the intake then get a coat hanger and bend the tip so it is round,then work it down into the hole where the hose was connected to the base.you should be able to push push out the clog through the bottom.also clean all the filters real good.you can also take the filters out and then turn it on if you have suction then ,then its the filters
Dec 29, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Suction not working
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 25, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
Chris...
Sep 24, 2008 | Dyson DC07 All Floors Bagless Upright...
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
151 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
