Question about Hoover Vacuums
Why does the water leak from the bottom of my hoover rug shampooer as soon as I attach it to the machine?
    Genius:
  • 1,181 Answers
Known problem we return ours twice, finally changed brands
Posted on Dec 13, 2016
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on bottom of hoover rug cleaner not spinning
The most common reason for this is that the air driven turbine has failed. To test it, insert a screwdriver into the square hole that the brush pin normally fits into and see if it turns. If it does not turn, the turbine assembly will need to be replaced. To prevent failure in the future, always store the shampooer with the upper tank removed, and squeeze the trigger to thoroughly empty the soap solution from the machine.
Jun 07, 2011 | Hoover Vacuums
My Hoover SteamVac Max Extract 77's dirty water tank won't fill. The water seems to just filter right back to the floor. What do i do???
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Jan 22, 2011 | Hoover F6055-900 SteamVac Maxextract LS...
Fairly new Platinum series Hoover Max extract wont turn on
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Feb 18, 2010 | Vacuums
Is there an online repair manual for a Hoover F7222-900 rug shampooer
You can download the Hoover manual that has some repair instructions and find repair parts below. Click the link
usavacuum.com/F7222
Jan 12, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes wont spin on my Hoover rug shampooer Model # f7220-950.
try cleaning brush...
if sam problem need replaced turbine part no: 43191009 Turbine & Gear Assem
Nov 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
Apr 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
