Question about Plumbing
My gould well water pump would not stop so is bought a new pressure switch which i installed and same thing. can you help me please
    Habit-Forming:
  • 28 Answers
Sounds like the foot valve may be loosing it's prime. I would let it pump for a few minutes and then shut it off. Then after a few minutes disconnect the line going into the well. If the line has water in it and the water level is going down, you have either a bad foot valve or a leak in the lines going down into the well. It could be as simple as a loose connection. Hope this helps. I use to sale well pumps and have seen this many times. If you let the problem continue and the pump continues running it will throw the overload or will burn the pump motor up.
Posted on Dec 13, 2016
Pressure switch clicks off and on will not stop
could be several things that cause this. I would first try increasing the spread between the upper and lower limits. it they are set too close together you can get this kind of bouncing on and off. Also, how old is the switch? as they age they get less and less accurate at reading the pressure accurately and this could be the problem. Longer shot, could be a leak in the well check valve. Water leaking back down into the well and that keeps turning the pump back on when there are no faucets open.
Jan 08, 2016 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Pump will not build enough pressure to shut off. New Bladder Tank set at 38 PSI. New switch set to cut on at 40-42 Psi. New Foot Valve, New Tank, New Pump. Blew line to well water a few days ago. Pump
check the water level in the well as it may be too deep for the pump to lift the water and maintain the pressure. Are you using a straight pump or an injection pump that helps lift the water to the pump. remember that centrifugal pumps only supply a vacuum in the suction line and atmospheric pressure on the water does the rest. when the weight of the water is equal to the pressure of the air the pump will not lift any more
Oct 05, 2014 | Goulds Pumps Goulds gt10 1 1 Phase...
How to fix double starts from points kicking the breaker
If the breaker is tripping you need an electrician to check wiring, pressure switch shouldn't be a problem. Don't try to work your way around electrical, always remember the unit will last longer if electrical is running properly to unit.
Aug 31, 2014 | Goulds Pumps Goulds RGS2012PA -...
Goulds pump pressure problem
What is the pressure rating range of the pressure switch??
Mar 07, 2014 | Plumbing
Gould water pump
That is one of two things. It is not pumping enough pressure to cause the pressure switch to trip. If the accurate pressure gauge shows it is above about 45 PSIG replace the switch, if not you have a problem with the pump. I am assuming it does not shut off. If it does then you have a leak, if a well pump it may be in the foot valve.
Nov 29, 2013 | Plumbing
Pump runing
check the pressure control switch for correct operation
Nov 29, 2013 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
My pump when reaches 40 psi clicks on and off contineously
check for a slow leak like a toilet valve. leaking tap in the garden or it may be the non-return valve in the unit is not sealing off and allowing the pressure to leak back into the pump so causing it to cycle. Mostly it will require a new unit to fix.
Jan 27, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
My goulds pump J15 does not engage
These pumps can be wired to operate on either 115 or 230 volts. This shouldn't be an issue if it was previously working. If a new installation, make sure it isn't be connected for 230 volt operation and supplied with 115 volts - and of course; vice versa. Correct improper wiring before continuing. It is very possible that the motor has catastrophically failed due to incorrect voltage being supplied - hopefully this isn't the case.
Check and replace / reset any open fuses / tripped circuit breakers. and try again.
These pumps are often operated automatically via pressure switch. If the correct power is available to the pump it may be a problem with the pressure switch. There are many different types of pressure switches so it will be difficult to go beyond what I have told you already. You might want to see if you can locate a pressure adjustment screw and try varying it to see if it has been set too low to allow the pump to come on.
If no luck, tell me what the application for the pump is (point well pump, etc.) and what controls the pump (pressure switch, etc.). Provide the make and model of the control device and any visible settings. Do not remove any covers unless the power is first shut off.
I hope this helps & good luck!
Jan 10, 2013 | Goulds Pumps Goulds J15 - Convertible Jet...
Plumbing Logo
248 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
