Question about Coffee Makers & Espresso Machines
Why does the water leak from the bottom as soon as I put the container on to the machine
  • 4 Answers
SOURCE: Saeco Coffee maker container is leaking
OK, I finally called Saeco. There are about four rubber rings that you need to get. The one for the water resevoir is a big thick black ring and once you get it and look at the new and the old, you can see why it is leaking. Anyway, fixes it no problem.
The overflow in the drip tray? There are two rings in the back of the machine that will fix that problem. Problem? I got them, but haven't put it on there because it very hard to get in there.
Last one, the ring around the coffee puck maker (what do you call that part) It's the piston that catches the coffe and raises up to tamp it down, then holds it as the water goes through. ANyway, big ring around that. If you aren't getting a nice crema on top, that ring will cure that.
I saw get all four, replace them all at once and then descale the coffee maker and be done with it. You'll be working like new in a few hours or maintenance. For most of us, it's been like 3 years anyway, time to do it.
Lastly, when you call Saeco, (Pronounced I found our SA Yey Co) ask for the directions for cleaning out the grinder. Even has notes on how to get it back together with all the adjustments in the right spots.
The rep on the phone says she likes this model better than most fo the new ones.
Posted on Dec 10, 2008
  • 59 Answers
SOURCE: water leaking out the bottom
Posted on Aug 20, 2009
  • 1711 Answers
SOURCE: water leaks from the bottom of the machine...
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
  • 3917 Answers
SOURCE: My Jura Capresso, Z5 is
The connectors on capresso machines are very tricky. The reason for the leaking could be to do with the seals. Take it apart and make sure all the rings and pressing clamps are in the right place. Also take a good look and on your hot water tank, and the pressure relief valve in back of machine.
Also it is recommended that the Jura coffee machines to be serviced every 2 years.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Posted on Apr 10, 2011
  • 13 Answers
SOURCE: saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Posted on Apr 22, 2011
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
My Delonghi N95 Nespresso machine is leaking water
on a N95 fill the water container and take it off the machine if it leaks its just the red seal on the botton but if thats not it put the water container back on full of water,let it sit for a bit,it wil leak out the front or side it will be the dark grey seal in the base were the outlet of the water container sits in, I found this with vmine anyway,it was hard to see it leaking but was a pain in the but!! i will talk to Delonghi or pull the seal out and match one the same
Feb 12, 2011 | DeLonghi Nespresso EN660 Espresso Machine
As soon as you put in water it leaks everywhere
at the bottom of the water tank there is a valve which is consist from a spring and plastic tab with "O" ring.
This valve and where is match with the base on the machine is dirty or full of scale or even bend or damage so as soon as you place the water tank back to the machine this valve does not fit excactly on the base threfore is leaking all over the machine.
First I sugest before you place the tank in place to inspect it over the sing press it with your finger and try to see there is something wrong as I mention above.
Then make a visual insect on the machine where the valve shoult fit.
Good luck
Mar 27, 2010 | Saeco Vienna De Luxe Espresso Machine
Sprayer is not working, but leaks water
I think you have two problems. The leaking is old seals on either the containers, or on the other end (the machine). Try replacing them. There are various part websites for these.
The problem with the spraying could be the belt that turns the pump. Check it. If it's there its probably not it. The next thing could be the little plastic tubes that go to all the componets inside the machine tend to accumulate buildup. Make sure they are all flowing free. Next try the heating element (its inside the handle area) take it apart and clean it. If all those things are checked and it still doesnt work, it might be what was wrong with mine. The all on one container that holds fresh water and dirty water has a leak. I found mine would spray correctly if i had the lid off the container, and as soon as i would put the lid back on it would stop spraying. I found out that The suction going through the container to **** the dirty water in was also putting a suction on the clean water bladder which caused the water to stop flowing out of the clean water bladder. I ended up getting an all new container with bladder because i could not get anything to seal right due to its age and warpage of the plastic. So to determine if yours is the same issue. Just take the lid off the container and then try to spray water. It may take 10 seconds to get all the tubes primed again because the suction will actually **** all the water back up to the container. If you dont want to replace the container, just spray a few passes with the lid off, then put the lid back on to **** the water back up. Hope this helps. I might not write clearly for everyone to understand, but i hope it helps someone.
Mar 01, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
It leaks a lot of water. I Checked the water container, the O ring seems okay. It does not leak by idle sitting but as soon as I make coffee the whole table is full of water.
Hi I would suspect that you have a ruptured tube inside. When the machine starts to pump it looses water from the tube onto the counter. It can be fixed.
Feb 04, 2010 | Saeco Royal Digital Plus Coffee...
Container leaking
Check the bottom of the container, there is a spring loaded valve and an o-ring, one of them might be damaged or not seated properly.
May 26, 2009 | Spidem Trevi Digital Coffee Maker,...
Water leaking out from water container
You either have a small crack on the water tank and/or the connection from the bottom of the tank reservoir to the machine is not sealing properly. ( i.e similar to putting the tank on top of a flat surface, the tank will leak as the seal connections gets pushed up and water begins to flow out)- it is that component that I am refering to. If you can inspect it to pin point the problem - if the latter is the case (valve), could try purchasing a new o-ring, piston, and valve. Suggest contact
. Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support and they will give more detail or contact SAECO via e-mail at :
Jun 20, 2008 | Saeco Magic De Luxe Espresso Machine
BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Jan 29, 2008 | Hamilton Beach BrewStation Deluxe 47474...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
