Machine indicate d---139 how settle problem - Washing Machines
Is my blood pressure to high at 138 /85
Readings between 120/80 and 139/89 usually indicate PRE-HYPERTENSION or HIGH NORMAL, indicating you don't have hypertension but your blood pressure is higher than what experts consider optimal for most adults. or in my case this is normal, not every one has the same blood pressure. im not a doctor but this should help you if you feel unwell please go see a doctor.
Jul 24, 2017 | Health & Beauty
Dressmaker model 139 where to find manual
You can purchase a manual for you model at the link below for your sewing machine. You can either download a PDF file or order a printed copy.
Jul 05, 2017 | Sewing Machines
Pfaff 139, need to replace motor to fly wheel round belt
There are plenty of sewing machine belt suppliers on ebay. A 41/2" diameter universal rubber belt should fit your machine
Feb 23, 2014 | Sewing Machines
How to thread bobbin on de luxe 139 zig zag
Try look in utube on sewing machine threading, if you cannot get your model, opt for your equivalent front drop-in bobbin or top loading bobbin threading.
Nov 02, 2013 | Sewing Machines
How do i settle a batch from the previous day when the machine won't settle automaticly?
You can hit settle key.. Grey Button on top.. It should print out a receipt stating Batch Successful
Oct 12, 2013 | VeriFone Omni 3700
I need Pfaff 139 instruction manual$FILE/Pfaff%20138-139%20.PDF
I just found this website with a clear version of the manual for Pfaff 138/139
Hope this helps did me.
Jun 08, 2012 | Sewing Machines
Codes for hitachi remote
Three digit universal remote setup codes for Hitachi TV are:
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit codes are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 07, 2012 | Hitachi Televison & Video
I just inherited a Pfaff 139. Can you tell me what year it was made? I tried sewing with it and I think the belt is a little old. On the bottom of the machine there are these letter: GZ-01022. On the front...
Hi! Congratulations! I just read a great review of your machine at One of the things the reviewer noted is that the 139 wasn't designed by Pfaff. It was designed by another sewing machine company (the GZ in your serial number) that Pfaff had bought. The machine dates to the 1950s.
Statewide sewing ( has a great selection of belts.
Hope this helps!
Happy Sewing
Feb 15, 2010 | PfaFF Sewing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
