My washing machine will not stop spinning - even if I turn the dial to the off position ! The only way to stop it is to open the lid
  • 641 Answers
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Posted on Jul 26, 2007
  • 1894 Answers
SOURCE: 2463200 - loud bang then spin stopped
hello sir
Posted on Feb 18, 2008
  • 1294 Answers
SOURCE: Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
Posted on May 10, 2008
docjohn174
  • 943 Answers
SOURCE: simpson enduro washing machine 701
HI thanks for the question. I would replace the water valve . this is a sign of a faulty valve. thanks . rate my answer please
Posted on Oct 07, 2008
  • 1028 Answers
SOURCE: Washing machine won't spin until open and reclosed the lid
sounds like transmission not resetting for spin properly replace transmission
Posted on Nov 21, 2008
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
My Magic Chef machine is 17 years old, but looks like new, so I hate to part with it. It stops during the SPIN cycle. I fiddle with it, like turning the dial around a couple of times and it will come to...
check the lid switch,it is located in the area where the lid lands on the washer housing when closed it is a safety feature that shuts off the machine if you open the door during the spin cycle,they can get touchy due to vibration from running,also check your balance ring,if you have a severly unbalanced load it will stop the machine
Jan 25, 2010 | Washing Machines
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Will not pump out the water
You have a bad lid switch. Open the control console. Remove the lid switch wire. Make a jumper wire from a insulated piece of wire. Insert it into the lid switch harness connected to the machine(not the cabinet). Turn the dial to spin. If it spins replace the lid switch.
If it makes motor noises and does not spin,replace the direct drive coupling on the motor.
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not stop spinnig
You probably have a blocked pump. Pull it out and clear the obstructions- buttons, lint, etc
Jun 02, 2006 | GE WJSR2070B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
