Question about Generac Electrical Supplies
Does anyone know why generac generator won't keep running? It shuts down after about about 10 seconds. everything is in good working order: battery, filter, oil, tank is full with propane, etc.
    Sergeant:
    Habit-Forming:
  • 153 Answers
Which model is it?
Posted on Dec 13, 2016
Testimonial: "4675 15KW"
  • 3 more comments
  •  Generator Guru Parts
    Not a Generator I have worked on or hold parts for, but I would be sure in saying it will be the Oil Sensor CDI (mostly likely) or the oil sensor has blown.
    To check, unhook the oil sensor CDI wire where it enters the engine. Run the engine. If it does not shut down you need a new CDI or your engine oil is low.
    If it still shuts down... Check the spark next. :)
  • silvana lazzari
    silvana lazzari Dec 13, 2016
    will try above and get back to you, also, all the LED lights come on as well and can't seem to clear same or reset
  • silvana lazzari
    LED lights meaning the message control lights
    As I say not one I have worked on. You need to get a manual or a Generac Engineer to help you. Sorry!
    BTW take note of the lights as they will indicate what the problem is in the manual or to the engineer.
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Generac xl 4000 will not keep running after starting
try disconnecting the wire going to the low oil switch. if it runs then you need a new switch.
Sep 02, 2017 | Generac Electrical Supplies
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
I have an older model Niagara 4kw by generac with low hours. I started it recently for the first time in 3 years. It ran fine but produced no current. I checked the brushes and cleaned the slip rings but...
I have not seen yor generator in practice, but saw some pictures of it.
As it is an older model, but it is not rare for modern generators too, when they stay a lot of time (3 years is a good lot of time), they lose thier magnetism.
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
Jul 31, 2010 | Generac Electrical Supplies
Generac NP 50G Stops after 2-30min.
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Oct 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Electrical Supplies Logo
51 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
dennys23601
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
