Question about Cameras
How do I get digital display to turn on? - Cameras
  • Cameras Master
  • 5,375 Answers
Basil,
First of all, there is no need to repeatedly post your enquiries - once is sufficient. Secondly, to get the information you require, you need to ensure that you post your query in the most appropriate forum - in this case, Male Jewellery. The use of the word 'Please' might also encourage people to reply to you more promptly.
Is this information not contained in the watch manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Posted on Dec 13, 2016
Why no display on lcd screen when shooting?
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
Press once for Normal view in LCD viewfinder
Press twice to turn on Rule of Thirds grid lines
Press three times to turn off LCD display
Press and hold 1 sec. to decrease/increase LCD brightness
Apr 25, 2014 | Canon G12 Digital Camera
Display not working on g12
Jan 05, 2014 | Canon G12 Digital Camera
My display off when i flip the lcd
  • Press once for Normal view in LCD viewfinder
  • Press twice to turn on Rule of Thirds grid lines
  • Press three times to turn off LCD display
  • Press and hold 1 sec. to decrease/increase LCD brightness
Aug 10, 2013 | Canon G12 Digital Camera
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
Need car stereo code for honda accord 1995
stereo codes for Honda
Method 1 (all applicable models except '03-07 Accords with the navigation system)
1. Turn the ignition switch to ON (II).
2. Turn on the audio unit, and make sure you see stereo COdE in the display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
3. Turn off the audio unit.
4. Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
Method 2 ('03-07 Accords with the navigation system)
1. Turn the ignition switch to ACC (I).
2. Turn on the audio unit, and make sure you see COdE in the upper display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
4. Press and hold the top halves of the SEEK/SKIP and CH/DISC bars, and then press and release the PWR/VOL knob. This display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
5. Call Honda Dealer for Radio Code.
6. Use the TUNE knob to enter the first four digits of the anti-theft code into the audio unit. (Ignore the last digit; it's not used.) When you turn the TUNE knob, COdE disappears, and a single digit is displayed. Turn the knob left or right to select each of the anti-theft code digits. When you press the TUNE knob, the system beeps and accepts each digit as it spells out CODE on the display.
https://radio-navicode.honda.com
May 04, 2010 | 1995 Honda Accord
I need to get a radio code for a 1999 honda accord
2. Turn on the audio unit, and make sure you see COdE in the display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
4. Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens:
- The first screen displays a U and the first four digits of the serial number (for example, U2200).
- The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
If this don't work, definitly you need to call Honda delaer using your VIN.
Hope this help.
Mar 18, 2010 | 1999 Honda Accord
I just replaced the batteries in my HP 12C calculator and when I turned it back on the display looks like this 0,000. How do I get the display to show decimals instead of a comma?
Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so,
turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
Oct 06, 2009 | HP 12c Calculator
Turn on the camera, no display, but it still takes pics
I have a Canon digital camera and can turn on an off the display. There should be a button in your Sony do activate the display. Cheers
May 23, 2009 | Sony Cameras
Fuji finepixA340
I suppose you've already turned the dial? Yea, on my camera there's dial ontop to turn to select the display mode, and then I turn it to the "shoot" mode, its usually a camera icon.
May 23, 2007 | Fuji FinePix A345 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
