Question about Watches
How do I get digital display on - Watches
My Casio analogue display is showing 5 minutes slow whilst the digital display shows the correct time
If old model ana-digi watch you have to manually synchronize analog time with digital display.
Nov 15, 2015 | Casio Watches
Waveceptor 3310 Frozen "H-S ET"
You must set the digital time as well.Analog time (hands) follows digital time.At first press button A.If digital time is according to analog time ok.If not you have to follow "H SET" (hour setting) procedure.
May 01, 2014 | Casio Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Hands do not show same time as digital display. the hands are two hours and several seconds behind the digital display. the digital display is correct. when I press the A and B buttons simultaneously...
    I have a Casio which had a similar problem and had to resort to reading he instructions to align the times!
    I presume that instructions for your watch are not to hand but you can get instructions from the Citizen web site.
    Go to "" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
    Fill in the information required from the back of your watch and then click on "get setting instructions"
    Mar 20, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
    Display only displaying parts of the digits
    It could be the battery is dieing or your watch is finally giving up. Go to a local retail store to test the battery out, if good then yes your watch has said good-bye.
    May 25, 2009 | Watches
    I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
    Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
    Nov 01, 2008 | Rado Diastar Anatom Jubile watch
    Setting the hands on this watch
    press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
    Now hold the "forward" button and the minute hand is moving.
    Enjoy :o))))
    Nov 28, 2007 | Casio Green G-Shock Street Rider with a...
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
