Question about Refrigerators
I arrived home from vacation and everything in the refrigerator was frozen. There was much less in it than usual. It was on 7 out of 10 for coolness. Would that cause everything to freeze?
    Master:
  • Refrigerators Master
  • 610 Answers
The machine is set too cold. Yes, this can happen when the machine goes from being used regularly, to not being opened at all when the control is set that high, but I would also check for proper damper operation... Help Me Find My Model Number
Posted on Dec 13, 2016
Frigadair top freezer thaws and is soft frozen when we come home from vacation, food is still cold 20 degrees, then while home freezer works fine?
Probably defrost timer not working properly, or the door is not closed or defrost depends on freezer door opening?
Appliance parts websites usually are very helpful.
Apr 02, 2015 | Frigidaire Refrigerators
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerator not keeping things cool and freezer
this is usually caused by dirt either around the fan if its a built in fridge, or around the cooling fins at the back of the fridge.Make shure you unplug the fridge before investigating what is wrong.
Apr 13, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator stopped cooling
the problem is in your freezer !
open the back wall of your freezer and check if the fan working then if you see a big build up of ice. then its your heater unit or your heater thermostat. to check that it is the problem unplug the unit defrost the freezer coil with hair drier gently and when it done plug it again and see if your fridg get cool (1h or 2) then you know its the heater unit or the thermostat :(
911servicetoday .com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
When on vacation you can't go anywhere
are you using windows xp or vista on vista this happens
Jun 07, 2009 | Electronic Arts The Sims 2: Bon Voyage
Refrigerator not cooling.
for what you say you have defrost problem
Apr 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
