SOURCE: Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
SOURCE: My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
It is the color wheel. Impossible to do this yourself.
SOURCE: no picture.
Most likely you need a new projection lamp. The "strange sound" you hear is most likely the lamp trying to fire.After awhile, the set"gives up' and shuts down. There is a small door in the rear, and the lamp is behind this. It pulls out, after removing a couple of slotted screws. The bulb inside of the housing is what goes bad--the housing does NOT need to be replaced, unless you get an "original"(read:: more expensive) mits lamp.
But a "generic' is available to replace the bulb in the housing ,Probably a P22-150, or 180 lamp, about a $300 repair, if you have someone come out--or, if you are mechanically inclined, you could replace the bulb from the old housing(EASY to do), yourself, and save about half of that, or perhaps more.
For more details type in this site name "Electro-help"
either to Google or Yahoo search box [not
in the address bar of your browser], and click search or press
Enter. It is an electronic equipments
service help site.
Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site
name, either at the bottom part of first search page, or at the top of second
page.
Detailed
descriptions are there to help you.
Sometimes,
clicking on advertisements by the side and bottom of each post might help you
to get details about the availability of spare parts; price and more.
