Question about Kitchen Ranges
Cooktop Locked Up!! I did all troubleshooting ..wont unlock top cooking elements but the oven works just fine. Fridgidaire CPLEF398DCJ
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
  • 833 Answers
SOURCE: RB525 Electrice Range
You have an electrical fault in the connection to your stove or in your home. I believe that the neutral connection that is one of the three or four wires connecting your stove is loose or lifted off. Get an electrician in to solve your problem.
Posted on Mar 07, 2008
SOURCE: "Cooktop Locked"
We found the manual. Held the button down for 3 seconds and it turned off. Felt like idiots!
Posted on Jul 19, 2008
chessmaster2
  • 160 Answers
SOURCE: Creda C461E Cooker
the control thermostat may also have been burned out. check it.
repair manuals can be located from here.
http://search.msn.com/results.asp?cp=65001&RS=CHECKED&Form=CO&v=1&cp=65001&q=appliance+manuals&Submit1=Go
Posted on Dec 05, 2008
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Posted on Oct 21, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Need 4 Creda stove top range burners that are 7.25 inches round with 2 sides being square on each burner.
Creda Cooktop Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/creda/cooktop/
my gas cooktop was continually clicking and smoke ... i am looking for the manual fora creda colonial t ... Creda glass cooktop GH100, need a burner ignition.
Creda Spares, Parts & Accessories
www.4creda.co.uk/
We have parts for the full range of Creda models, so we're sure to have the part you ... Get the best performance from your Creda cooker hood with our range of ... fan oven elements, replacement control knobs, door gaskets and oven hinges.
CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20 ...
bellingham.craigslist.org/app/5414687535.html Craigslist Inc.2 days ago - CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20" HIGH ... make / manufacturer: CREDA ... The grates have some cosmetic chipping.
Jan 25, 2016 | Creda Kitchen Ranges
Es510
Hello KC - You may try and reset the cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the lock symbol does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control), user interface board or a potential wiring failure. This is not a typicaly do it yourself job; please consult a professional or your manufacturer.
Apr 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
The oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
Aug 05, 2009 | Frigidaire Gallery GLEFM397DS Electric...
My cooktop is locked and I don't know how to unlock it. I did a self clean last night and the oven works fine.
Push in on the oven light switch and hold in for about 5 seconds cook toplight switch will go out same to lock it again.
Jan 24, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
SMEG Oven SA9066XS
If this is an Electric over, the heating element is damaged. The device has a open connection. These element break down often. Usually, the manufaction will sell this whole element as one fixture. They are usually easy to replace.
If it is a Gas oven, the polit is out. Sometimes they go out, and its ok to relight them. But this sounds like an Electric over!
Oct 22, 2008 | Smeg Ovens
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
