Question about Honda Garden
My pressure washer pump is a RKV 4g36 mount in a Honda . Will a pump model RSV4G40 fit. ?
  • 30 Answers
SOURCE: I'm trying to find out how much oil should be in
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Posted on Mar 11, 2009
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
  • 583 Answers
SOURCE: I have a DeVilbiss pressure washer, Serial#
THE PUMP FITS THE MOTOR and the pump i always use is a ROYALPUMP made in Italy and they are long lasting and easily serviced ,any of the Italian pumps are good
Posted on Sep 10, 2009
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
  • 68 Answers
SOURCE: For pressure washer Model WP-2402-SWHB,
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Posted on Feb 08, 2010
How much oil does the Anrovi. RkV 4g36 take
rkv pump half of sight glass on back cover any excess can cause over flow if back cover has no sight glass then you will have to use the dipstick do as follow fill pump crankcase while inserting the dipstick til it stops without screwing it in then remove the dipstick and place the end to the pump casing if you see oil your okay cause by the time you fully insert the stick its gonna show where it should be and again half the sight glass:):)best oil to use is 30w non-detergent oil
Jun 18, 2013 | Honda Pressure Washer PSI 3000
How to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
RKV4G36 will not pump water. The "expert" that was using it says it needs to be rebuilt. About 3-4yrs. old with maybe 100 hours on it. Was told he started it w/o water turned on. Rebuild? New...
Bad news if he ran it without water he may have damaged the seals inside. If you screw in your water hose and water immediatly leaks from pump head then those seals need to be replaced they cost about $75. If its an RKV pump they are very resiliant and expensive they are usually worth rebuilding.
May 06, 2011 | Annovi Reverberi RMV2.5G27D Pressure...
Hose broke off fitiing
If fitting on hose broke off, replace hose. If the fitting on pump body broke off it may be a special fitting with a siphon fitting for soap induction which means it may be a model specific part. Start with a model breakdown of parts for your model PW. Honda made motors for a few different PW models and the water pump casing will change with manufactures.
Apr 08, 2011 | Honda Garden
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
I have a DeVilbiss pressure washer, Serial# 2251136878, Model# WVRH2421, Radial Pump# D28703, with a 5.5hp honda motor. It has no pressure. If the pump can't be fixed, is there another brand of pump that...
Sep 10, 2009 | Garden
Garden Logo
124 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
