Question about Tablets & eReaders
Owner Manual for my Micro USB Charge/Sync Cable
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Is it ok to charge my RCA tablet pc w/a micro mini USB?
if the micro mini usb port fits the tablet ---yes as that is the cable used to charge it with
Dec 21, 2015 | Tablets & eReaders
Why doesn't my tablet pick up wifi
Open your tab and check the wire or flix of your wifi connection maybe it's broken connection then fix it by soldering iron
Sep 13, 2015 | Evecase Evecae Black PU Leathe Folio tand...
My CURTIS KLU LT7035J tablet only works when I have it plugged in. It won't charge and I have been trying to charge it for days ? Nothing in the manual on what to do...should I return it or is
Please ensure you are using the correct power adapter that came with the tablet. If it is the wrong voltage/amps then the charging function will protect itself. If it uses a micro USB end then try charging via a computer USB port using a USB to Micro USB cable. This should work and will possibly eliminate the Tablet from the diagnosis. DON'T try to make your own power solution from a combination of cables/adapters because it's potentially dangerous to both you and your tablet.
Dec 01, 2014 | Curtis Tablets & eReaders
My kindle will not charge
Use a different charger - se if any of the ones you have for your phones are Micro USB - they will charge it fine.
If not get a usb/micro usb cable or micro usb charger from most shops in the high street for 4 or 5 pounds.
If using the usb jack on a pc or laptop swap to a different usb jack on the pc or laptop
Feb 28, 2014 | Amazon Kindle 3G
Playbook totally drained power cannot charge
The problem may be with your charger, Micro usb cable or your micro usb port. The blackberry playbook rapid charger uses the little brass buttons to charge and will help you diagnose if the problem is with the playbook battery or if the problem is with the micro usb connection.
Feb 17, 2014 | Tablets & eReaders
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
How do I charge my ereader
No idea which brand it is. It should have come with a usb cable in the box. (Kobo / Nook / Kindle / Sony)
Plug the cable into the eReader and then into a USB port of a pc and start charging.
Most phone chargers now are also micro usb so can be used to charge if they fit. (Obviously don't try and break the thing ramming it in.)
Jan 20, 2014 | Tablets & eReaders
How do i charge the kindle
With a USB / Micro usb cable connected to a PC or Laptop - one came with the Kindle (it's the white cable in the box) or can be purchased for about 3gbp from most supermarkets.
Look to see if the charger on your mobile phone is also a standard micro USB connection. If it is use this to charge your kindle.
Dec 15, 2013 | Amazon Kindle Paperwhite
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
