SOURCE: Error 00183
I think either your camera is damaged (accident) or there is some software problem. Go to the nearest service centre if under warranty. or there may be some software problem. take out your memory stick and scan it for viruses with some good antivirus program. then put it back. it should work. if it does not, let me know
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Testimonial: "very helpful thanks saved me lots of money "
SOURCE: Hi, I have a commercial
Hi.
If there is incline fault, then the sensor must be calibrated. The error may happen even if you do not do anything. sensor goes out of calibration and you get e5.
The only reset you can do is by disconnecting power and removing console batteries if installed (that depends on the treadmill model).
I suggest contacting Techogim and following the procedure to calibrate the sensor. Contacts are listed at the right hand side of this page, click: Contact Us.
SOURCE: Screen glitches, freezes and ends
Test all leads that attach to your hard drive including electrical extensions IDE,SATA the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all power and data to travel to and through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket also
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers
if you need more help with this post a reply
hope this helps
SOURCE: technogym treadmill user manual
go to this website:
www.iconservice. com
or http:// fitness.manualsonline.com
give your model, etc, and download for free.
sincerely.
Happy New Year, G-d bless you
ernesto cuadra
managua,nicaragua c.a.
