Question about Home
My technique model 99805 6 1/2 quart pressure cooker just stopped working. only used it about 15 times but now nothing . Doesn't turn on or anything.Did it just die or is there something I can do?
Purchased from the sportsmans guide about two years ago.
  • 8596 Answers
SOURCE: It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Mar 24, 2009
SOURCE: Cooks Essentials CEPC800 It just stopped lights
You can join the yahoo group: PressureCookerRecipes and they have a file that shows step by step how to change the fuse for this pressure cooker. Hope this helps.
Posted on Jul 07, 2009
  • 1335 Answers
SOURCE: Need pressure cooker manual
The pressure cooker is make by Denmark PC, you can download a manual from and care?id=61&cl=CL1
It's either hard anodized or polished aluminum.
Please rate this solution. Thanks.
Posted on Jul 11, 2009
  • 2049 Answers
SOURCE: lost owners manual
Here's a link to this manual directly from QVC...
Posted on Sep 02, 2009
The answer of "Firehead" is correct. You have a start/stop valve with springs (springs = maybe broken by the rust). Kew sells a kit to repair. If you want i'll send a diagram to you.
JJ (Brussels)
Posted on Oct 30, 2009
Technique model 89759. Where can I get a user's manual?
pressure cooker manual & recipe booklet library ' hip ...
Dec 14, 2015 - Free downloadable copies of pressure cooker instruction manuals for stove top ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet .... SunbeamPressure Cooker Manual; Technique Pressure Cooker (see Deni); T-fal ... Tower (see Fagor for similar models); Tramontina Pressure Cooker Manuals ...
Technique Oval Talking Electric Pressure Cooker Manual ...
Oct 7, 2009 - Technique Oval Talking Electric Pressure Cooker Manual. 44 ... ForTechnique Pressure Cooker model numbers: 99800, 99801, 99802, 99803, ...
Technique by Cook's Essentials Digital Pressure Cooker ...
Oct 18, 2009 - For Cook's Essentials Model Number: DYB350 Please wait a moment for ... Technique by Cook's Essentials Digital Pressure Cooker Manual.
Jan 19, 2016 | Home
Where can I find an oval gasket for an 8 quart Cooks Essential pressure cooker.
The manufacture of the Cooks Essential pressure cooker is Fagor America. You can buy the gasket directly through them. The 8 quart cooks essential uses a 10" gasket.
Here is a link to the site: Fagor America Shop
Apr 22, 2015 | Cook's Essentials CooksEssentials 8 quart...
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Sep 21, 2014 | Cuisinart CPC-600 6 Quart Electric...
Cooks essentials manuals
Well, it depends on the model, I looked the digital pressure cooker manual (found here E4 is a Signal Switch Malfunction. The recommend turning off and un-plugging the pressure cooker and letting it cool of completely before trying to use it again.
Aug 12, 2014 | Cook's Essentials CooksEssentials 3 Quart...
Technique digital pressure cooker stopped wprking after using slow cooker on pot
Actually, Technique pressure cookers are known to have a high failure rate. Contact the seller or manufacturer immediately to get a replacement.
Here is the manual for it, see the notes below and comments from people who have had the same problem.
Jan 01, 2014 | Coffee Makers & Espresso Machines
My nesco digital pressure cooker stopped working
Likely the fuse needs to be replaced. Bring it to your local electronics store and see what they say!
Nov 09, 2013 | Nesco PC6-25 1000-Watt, 6-Quart Stainless...
E4 code
before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error
Jan 24, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Cook's Essentials PRESSURE COOKER
I have a cook's essentials pressurer cooker 5 or 6 quart and I have lost the instructions on how to work the pressurer cooker........can anyone help me with the instructions............
Dec 27, 2007 | Kitchen Appliances - Others
Home Logo
95 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
