Question about GE Ovens
I have a GE JK950BOA2BB double oven/broiler unit. I am unable to get the lower broiler to work. Both upper/lower ovens heat to temp. And upper broiler works. What do I need to do for lower?
  • GE Master
  • 5,323 Answers
SOUNDS ,LIKE THE BRIOLER ELEMENT BURNED OUT , U CAN TEST IT WITH A MULTI METER. SEE PICS
I have a GE JK950BOA2BB double oven/broiler unit.  - 26397475-qutyvmxjxsypifp3xmovxlxe-3-0.gif
26397475-qutyvmxjxsypifp3xmovxlxe-3-2.gif I have a GE JK950BOA2BB double oven/broiler unit. - 26397475-qutyvmxjxsypifp3xmovxlxe-3-5.jpgt/uploads/images/26397475-qutyvmxjxsypifp3xmovxlxe-3-5.jpg" alt="26397475I have a GE JK950BOA2BB double oven/broiler unit. - 26397475-qutyvmxjxsypifp3xmovxlxe-3-9.jpg"h_mi" />
Posted on Dec 17, 2016
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
GE True Temp lower element not working after being replaced
sounds like you got a defective element
Feb 08, 2018 | GE Ovens
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
60 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
