Question about Hardware & Accessories
Can I replace Aristan 999599 mechanical timer with a digital one. If yes please advice which one.
This mechanical timer is for the Aristan MicroGenus model MFFI 27. It is also called as Grasslin 02.76.0126.1 mechanical timer
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
SOURCE: I have a Grasslin talento 371 easy timer (digital)...
Try this link 6.7_talento_371+372_(V97_1_2digixx)_ls1_xx.pdf
Posted on Sep 23, 2010
  • 127 Answers
SOURCE: Need user instructions for a Grasslin iht d120
Took a little hunting but managed to find it for you.
Here's the link to the manual including programming instructions.
Have a great day
Posted on Dec 29, 2010
SOURCE: instruction manual G1921 Grasslin Digital Timer
I don't have a manual for Grasslin G1921 timer.
You posted under photo of GE15079 which coincidentally has same buttons, but may or may not have same programming
Open following link to identify timer similarities.
GE 15079 manual:
Add a comment and say if these timers are both programmable with same instructions.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 04, 2011
SOURCE: Hi I have a grasslin
Mine has just developed the same fault, did you find out what the problem was.
Posted on Dec 05, 2011
Sorry Terry - I'm not used to this site! Question was - anyone know what the error message E34 means on an Ariston Boiler MicroGenus 24HE please?
The information I have found states it is a problem with the pressure switch. A faulty pressure switch will prevent ignition from occurring. Here is a Youtube video link showing the issue. Reading the comments below may assist you in isolating your problem. Hope this helps!
Ariston microGENUS 24 HE MFFI Error 34
Oct 21, 2015 | Washing Machines
Digital display stopped working electronic timer
Identify timer.
Replace battery.
Do not use battery-operated timer in cold environment... look for temperature range when selecting timer.
Mechanical timers will work in cold temps.
Or buy another timer to replace defective timer
Nov 23, 2013 | General Electric Hardware & Accessories
How do i set a ariston timer 999599
1) Ariston 999599 is ordinary 24-hour FM1 analog timer from Grasslin.
2) The timer dial rotates around each 24 hours, and pins are pushed outward or inward to set on-off times, and are dependent on wiring and position of override switch located on front tof timer dial.
Copy following link for setting analog timers.
3) After opening links above, add comment and attach photo of your timer.
Feb 18, 2013 | Hardware & Accessories
The wall timer to my outside lights says
yes they are horrible,you can try pushing very ******* the on off button and holding for extra long my best solution is to replace with a regular switch and install a photocell anywhere between the switch and your first light including at the first light. much more reliable and much less expensive. can also get photocells with dusk to dawn opperation that will allow you to control how long your lights stay on after dark 2, 4, 6 hours or all night . mechanical timers are also very reliable but expensive big and very industrial looking usually installed in a garage or mech room good luck
Jul 15, 2012 | Intermatic Inc. ST01C Digital In-Wall...
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Washer continues to run but the timer stops at 42 minutes
OK I see it.
Most likely problem is the timer. The timer tells the machine what to do and when. Yours is sticking at the 42min mark.
I do not see the model number so I'll take an assumption.
Digital timers are integral to the control panel and can be replaced as part of the panel.
Rotary dial timers are easily removed and replaced.
Switch the breaker off. Do not touch the control panel without first having done so.
To remove the control panel there are screws around the outside of the door frame and on some units from inside the machine on the door frame. Remove them and the control panel will be exposed.
If you have a rotary dial timer remove the control knob (pulls off) and the screws retaining the timer inside the control panel. You can sometimes "fiddle" with this style timer and get it going again. It is usually just dirt struck in the mechanism stopping it turning. But it is not expensive and I'd just replace it.
Digital is another system. If you can remove the timer section as a unit then you can replace it. Fist I would get the model number and go to your local parts dealer. Ask it you can get just the timer. If so replace it. There are no serviceable parts in an digital timer.
I hope this helps you. Please rate it is it helps clarify for you.
Mar 10, 2010 | Whirlpool Dishwashers
Does it have a timer for self-portraits?
Yes, it has self timer function. Please check button that has clock symbol, press it to select self timer, press shutter button to activate it.
Hope this ifno will help you.
Dec 04, 2009 | Sony Cyber-shot DSC-W180 Digital Camera
Timer button won't rotate and dry time is very long
The timer has a little motor in it that causes it to turn and it sounds like it has failed. I'm assuming you can manually turn the timer all the way around. If you can, then it is not mechanically stuck. It's the motor within the timer.
Replace the timer/controller.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Hardware & Accessories Logo
66 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
