Question about Goodman CACF048B2A Air Conditioner
Cold air comes out but doesnt blow
I have cold air slightly coming out, it is not blowing cold air, I cannot locate the filter, the system was put in 3 years ago. This is driving me nuts
  • 614 Answers
The filter in a Goodman unit is in the Air Handler located at the bottom of the unit. Screw on either side take them loose and the filter pulls out. Now trun of fan first so the filter will come out easier. You may ahve other problems like stopped up coil or low on refrigerant. Russ
Posted on Jul 21, 2009
What is the problem? How do I fix it? Resistor Pack? Fan Control? Entire AC system?
your problem could be in your control switch panel itself. pull out the control panel and check the connections with a Probe Light Tester. The following video is for a Volvo but is used here only to give you an understanding of how to remove your A/C Control unit to check for poor circuitry. https://www.youtube.com/watch?v=SmCKFx1B4cA
Dec 17, 2015 | AC Cars & Trucks
Why does my 2005 ford freestar a/c system condenstates but does not blow out cold air?
make sure your cabin air filter is not plugged may need to be replaced
Jul 09, 2014 | 2005 Ford Freestar
A/c blowing hot air with low pressure
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
Jul 09, 2013 | Cars & Trucks
I have a 2003 toyota corolla. My AC would blow cold air for a min or two then when the compressor shut off it would no longer blow cold air or come back on. A new compressor was put in it but it did not...
the ac clutch relay is the problem. It is located in the under hood fuse box. It is a $10 part. The relay will make a clicking sound when activated but the contacts inside are burnt causing no electrical flow to the ac compressor. Simply unplug and replace. The relay is labeled M/G CLT .
replace or blow out the cabin air filter as well. It is located behind the glove box. Instructions are in your owners manual.
Oct 31, 2010 | 2003 Toyota Corolla
2000 montana ac not cold also the front right vents blows very good cold but not to cold and the left side doesnt blow very cold and not cold
sounds like it might be a little low on freon and/or might need the cabin air filter replaced,try replacing the cabin air filter first,its located behind the glove box,hope this helps
May 27, 2010 | 2000 Pontiac Montana
03 corolla air conditioning problems
If you were low on freon before, It's possible you have a leak in your system. If you take it back, have them check for the leak before they let you drive off with another freon loss.
Good luck...
Jun 11, 2009 | 2003 Toyota Corolla
Window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Jun 07, 2009 | Whirlpool ACQ189XM Air Conditioner
My air conditioner doesnt blow cold air turns on and blows but the air flow seems to be only a little house gets hotter and muggy
This is most commonly cause by a lack of freon in the system. Unfortunately, the only solution to that is to call your local A/C company and have a certified technician come and charge your system. The reason you need to call a professional is because you need a special license to handle the type of freon your system runs on.
This could also be cause by a dirty air filter.
Check the air filter to see if that's it. If it isn't, you need to call a service tech.
May 19, 2009 | Heating & Cooling
Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Goodman CACF048B2A Air Conditioner Logo
172 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
