Mike Springman Posted on Dec 13, 2016
Were R all fuzes for windows - Audio Players & Recorders
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
4helpful
Getting a message that says "Not enough space for Music DB. Please free up 90 MB"
Plug the USB cable into your Fuze, but don't connect the other end to your PC yet.
Switch the HOLD switch on (Power button slider down). Press and hold the |<< button while at the same time plugging the USB cable.
You should see your Fuze show up in Windows Explorer (run "My Computer" and you should see it there). Right-click on your Fuze and select Format. Note that this will erase all media on your Fuze, you should have a backup of your media on your PC.
Once the Windows Format is done, go to the Settings menu, then System Settings, then select Format. Select Yes to start formatting.
1helpful
2answers
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
Sansa fuze 8mb format and firmware update
go into device manager in computer management and uninstall the sansa driver. Restart the computer and plug it in again
6helpful
Sansa fuze FAT error
Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
2helpful
Cant view youtube vidoes
Youtube player is on the FUZE, it is located in the windows directory.
You will have to go searching for it. Use the File Explorer and go to the windows folder, you will find it almost at the end the file "youtube.exe"
Just use file explorer on the device and copy the youtube.exe file in the windows\startmenu\programs folder and then paste a shortcut.
Hope this helps!
Have a nice day!
- Neal
7helpful
Electric windows wont work cant find fuse
if it the old vitara i had exactly the same problem i shorted the fuze when trying to fix the windows and i could not find the fuze. By trial and error i found that the fuse is the round one next to the fuze box inside the car. Hope this helps.
Sync problem sometimes works and sometimes doesn't
I used Windows Media Player 11 to move music to my Fuze.
  1. Plug your Fuze into an USB port on your computer using the provided adapter cord. Windows will detect the Fuze and install it if need be.
  2. Once Windows has done its thing, open WMP11 and select the "Sync" tab.
  3. You can now drag and drop your music from your Library on the left to your Sync Playlist on the right.
  4. Once you've moved your selections, click on the "Start Sync" button at the bottom of the right side.
  5. The music will be uploaded to your Fuze.
You can have WMP11 detect your music and put it into your Library by pressing the F3 key. Press F3, navigate to your music folder with the Add button, and then press OK. You can remove folders from the list in the same manner.
 Grubhead
Grubhead
SmartAviator
SmartAviator
