Question about Samsung Televison & Video
I have a samsung ua55ks8500k which just shows different color on the screen from blue to green, white and red is there a way of fixing this
  • 192 Answers
SOURCE: Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Posted on Apr 15, 2007
  • 5138 Answers
SOURCE: Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
Posted on May 31, 2008
SOURCE: white colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Posted on Jul 25, 2008
  • 4 Answers
SOURCE: distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Posted on Aug 03, 2008
  • 1030 Answers
SOURCE: screen lookes like colores separating
Hey try this check under setup do you have the convergence option. if you do not you may have a simple little repair. Check out the article in the tips and trick section of this site intilted "the fl231 problem"
Posted on Dec 06, 2008
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
When my tv is on only shows colors blue and green the picture has been change
You sound like you are connected with a compnent video cable. Red, Green , blue for the video and red and white for audio.
Check the connection on the red video cable at both ends to make sure it's pushed in firmly. Also make sure you don't have the red audio cable plugged in to the video section accidentally.
After you fix it you'll need to reset any color changes you did to try to fix it before.
Tommy HD Installations
Aug 07, 2010 | Samsung HLT-5075S Television
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
No blue color on tv screen
Your welcome ! please comment. Thank you !
May 01, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Out of Focus
· Samsung parts for convergance problem
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
