BEFORE PLUGGING IN THE FIRSTTIME THERE WERE SOME STEPS. WE JUST PLUGGED IT IN. CAN YOU ADJUST THE LIGHT KEVEL?
I cant unlock kevel 51 on candy crush
If at first you don't succeed, try, try again.
Nov 21, 2014 | Video Game Consoles & Games
My DP8240 poes not power up. I have checked the power supply and it is delivering 12.3 volts.
If there is a standby light or indicator try unplugging the power supply and then pressing power on. Leave it unplugged for several minutes (a full 10 minutes is best) then try plugging it in a starting it again.
If there is not standby or ready light when it is plugged in try replacing the fuses in the device.
Let us know if this works or not and we can suggest some further steps.
May 02, 2008 | Televison & Video
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
I can't install or find firsttime installation formy freeview on the toshiba 32bv500b tv
On initial installation,the language menu disappears after a split second and the standby light disappears so I can't set the TV up at all
Feb 01, 2011 | Televison & Video
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
I plug in my player into the USB port, nothing happens.no light
If you get no light at all, it could be that the Swimp3 Player isn't plugged in properly. Try unplugging it and plugging it back in.
If you're plugging into a USB Hub, be sure the hub is on.
Depending on the Model of the Swimp3 - one of the older models would allow you to plug the USB in upside down - newer models do not. So I would also verify that.
The next step would be to press and hold the RESET button for 4 seconds - most other hiccups are cleared up with that.
If those steps don't work, I would contact the retailer where you made the purchase - your Finis player comes with a 90 day manufacturers warranty.
Good Luck
Michelle
Authorized Finis Dealer
Apr 20, 2010 | Finis Swi MP3 Player
Humming sound coming out of speakers, nothing else. Cannnot adjust volume.
What color port on the back of the system are you plugging your speaker in?
The speakers should be plugged into the GREEN port...sounds like you have it plugged into the Mic/Pink
Sep 12, 2009 | GE HO98010 Computer Speakers
Flashing green light and hour glass - performs no functions
Please perform the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet and see if the message still appears.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
May 26, 2009 | HP Photosmart 2410 All-In-One InkJet...
Printer won't print flashing green light
Please follow the steps given below and check the functionality.
Bypass the surge protector ====================
Power Cycling
2. Wait 30 seconds.
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
May 26, 2009 | HP Office Equipment & Supplies
26 people viewed this question
jasbo
jasbo
