Question about John Deere Garden
My John Deere 455 diesel garden tractor starts but immediately dies. After 10 starts, it barely stays lit at full throttle and then races to full speed. I replaced the fuel filter 2 months
    Sergeant:
  • 237 Answers
Check all electrical connections and clean ground wires.
Posted on Dec 20, 2016
John deere 455 keeps dieing
Clogged pilot jet inside the carb. You need to remove the jets and ream them so they are clear. If it starts and then dies as soon as you try to throttle up, then it is the pilot jet.
Apr 25, 2017 | John Deere Garden
John deere - 455 Diesel
check your seat safety switch
Nov 19, 2013 | Garden
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Oct 02, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
71 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
