Question about Sharp Office Equipment & Supplies
My sharp ar5316 when i switch on my machine not worked after that the third light is on what's the problem help me
  • 1362 Answers
SOURCE: sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not.
Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get.
If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings.
Are the strings broken , is the roller in place?
Posted on Oct 25, 2007
sir fixalot
  • 146 Answers
SOURCE: add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Posted on Jan 02, 2008
  • 2072 Answers
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this does not clear the problem the fuser will need replaced.
Posted on Feb 21, 2008
SOURCE: AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Posted on Mar 07, 2009
  • 7 Answers
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Posted on Mar 23, 2009
F2 indication
Depends on what machine you have
Dec 09, 2011 | Sharp Office Equipment & Supplies
My sharp ar5316 wont work it has the code H@ showing how can i fix it
what h4,h3,h2,all of this is for fuser unit ,press # press interrupt press C press interrupt then put 14 then start ,the machine will off and on again
Oct 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5316e is showing a red triangle blinking light and no key is responding nether the start button
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Jul 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Free xp driver for sharp ar5316 please!
Drivers for Sharp AR-5316 are available at Sharp Official Support site Click here and make selection as under: -
Select AR5316 > Windows XP
Good Luck!
Appreciate generously, if the solution could have been of any help!
Dec 19, 2010 | Office Equipment & Supplies
I can not set up my system with windows seven 7 please send softwere for my syetems . my sestem is sharp AR5316E
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Photocopiers > AR5316E > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
Sep 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
How can i scan an image to computer with sharp ar5316e
The Sharp product description page lists this device as a printer/copier. It's scan function will only produce local copies on itself and it will not scan to another device or computer.
May 27, 2009 | Sharp Computers & Internet
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
