Question about Radio Communications
I have some sort of electrical feedback through my transmit.on my 2970 radio. only on the peaks.radio has as as switch on the back to bypass the amp and problem remains the same.could you please help
fixyaupman
  • 3 Answers
SOURCE: One radio continually transmits
switch radio off ,remove battery for +- 5 min. replace and try agian .if problem exist ensure that u can hear the ptt micro switch cliking  when u depress it ,if not the ptt switch coud be faulty or sticky .also measure the battery voltage 'some radios go into tx mode when the battery voltage drops to a certain level .does the radio still transmit when it is charging?
GOOD LUCK!!
Posted on Oct 29, 2007
tparsenault
  • 170 Answers
SOURCE: Radio clicks on and off during transmit.
Hi Dispatcher,
There might be a few things going on here. You say you hear clicking, regulator woudnt be doing that as they are solid state. It could be a relay, some radios have relays instead of electronic switching when you key up.If the voltage is too low that can cause the relays to "chatter", I would look into that first. Can you take the radio to your vehicle and hook it up there ? ( If you are set up for that) just to see if your battery will drive it better.
Are you running a Kicker or modulator? Lets get this sorted out and see what happens,there are other things but lets try one at a time.
Good Luck,
Tom
Posted on Jan 01, 2009
eradiostore
  • 1654 Answers
SOURCE: my customer has 6 motorola max trac vhf radios.
If this is a new install, it is likely noise from the vehicles electrical system scrambling the processor of the radio. Put a filter on the power leads and check your install.
Posted on Aug 31, 2009
anymhz
  • 500 Answers
SOURCE: RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
Posted on Dec 08, 2009
  • 127 Answers
SOURCE: My new Karcher K2.900 pressure washer trips
sounds like power cable broken check all of it you might need to replace it
Posted on Jul 09, 2010
Got a cobra 29 ltd classic dead keys 10 watts and swings back to 6 watts on an external meter any answers
Hi you have to make sure your antenna has 1:1 SWR reading improper use of antennas deplete the Effective radiating Power of Transmitting equipment such as the CB radio.
Mar 15, 2016 | Cobra Radio Communications
Feedback through speaker during transmit
ARE YOU TALKING ABOUT THE INTERNAL SPEAKER IF SO THE WIRES TO THE SPEAKER INSIDE ARE BEING SHORTED TO GROUND TOUCHING SOMETHING METAL
Feb 24, 2013 | Radio Shack TRC-503 CB Radio
My cobra 29 has a 75watt amp on the back how can i get more
If you're using the RFX-75 amp section. Then you'll need to make sure your transmiter section is tuned for full output. The last last unit I installed in a Cobra 29 LTD, the radio modulated right at 100 watts output.
Hope this helps,
J.R.
Dec 22, 2009 | Cobra 29 LTD CB Radio
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
My customer has 6 motorola max trac vhf radios. all have same problem, they transmit just fine & then they just quit transmitting, they still receive but wont transmit until they turn unit off &...
Aug 26, 2009 | Motorola T9580RS Two Way Radio
RCI 2970
May 06, 2009 | Ranger RCI-6900F-150 CB Radio
RCI 2970 squeels until you unplug the external speaker and plug i
Strange! I used to run almost the same kinda setup but with a super scanner omnibeam, i modded mine myself. At 1 time i had a squeal problem it was in the mic if i remember correctlly i ran a external wire from the screw on the spring inside the mic where the cord comes out to the radio chassis and it stopped it give it a try. I used a simple speaker wire, also you might want to try grounding the radio to the power supply. Sounds like a ground problem! I have a awsome mod for that radio that would enable you to run a regular amp with it and also would enable you to talk local without engaging the amp in the radio using only 4 watts! Let me know how it works out for you with the squeal? if intrested in that mod contact via email at (noteethontop@yahoo.com). put 2970 in the subject line. Take care.
Jan 17, 2009 | Radio Communications
Hi Dispatcher,
Good Luck,
Tom
Dec 30, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Electrical feedback
phone knights 01652 648 378,its a common fault
Mar 10, 2008 | Magnum S9 Base CB Radio
Radio Communications Logo
59 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
