Question about Garden
I have power to joy stick when moved to operate plow light goes out solenoid doesn't kick in
humantoolbox
  • 110 Answers
SOURCE: Joy Stick
If a joystick sticks, there is no other option but to buy a new one (Sorry!)
http:/bestofferbuy.com
Posted on Dec 19, 2009
  • 177 Answers
SOURCE: no power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Posted on May 27, 2010
  • 57 Answers
SOURCE: I have bought a minute mount 3 plug plow. The
It sounds like there is an in-line circuit breaker which is either defective, or not big enough or the motor is drawing too much amperage. Check with the manufacturer and ask the questions: what size circuit breaker should be used and what is the minimum wire size required. Check against what you actually have. You will probably find a wire hooked directly to the battery and the circuit breaker is usually located first in line close to the battery. Too small wire size could cause a fire.
Posted on Sep 22, 2010
  • 692 Answers
SOURCE: lights scroll from lt to rt ant lights around joy
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Posted on Apr 16, 2011
SOURCE: Fisher plow only turns right no matter which way
having the same problem just wondering if you figured it out??
Posted on Nov 26, 2011
I have a fisher minute mount 2 plow for some reason it only goes to the right now , not up or left , no matter what button I press on the control it goes right .
Start by plugging everything in and pop the cover off the control part on the plow and check for magnetism on all 3 solenoids when you hit the various buttons on your plow controller. The pull should be very strong and noticable...a weak magnetic pull is likely just residual magnetism on your screwdriver. In my case, the S3 solenoid wasn't firing and that causes exactly what you're describing.
If your S3 isn't firing you can test the wiring by moving the S3 hot wire to the S2 solenoid. If your wiring is good the plow will misbehave in an entirely different way. Also get out your ohm meter and test the S3, if its good you should get 7 ohms on it.
You need to use the guide from Fisher and be methodical about it. Start at the plow and work your way backwrds towards the truck.
Jan 27, 2016 | Cars & Trucks
Plow will only turn to the right
It is electric over hydraulic most are, make sure the solenoid is clicking when you try to turn the plow. One side is working see what one is clicking the other one would be the culprit. If the solenoid are working then the problem is internal to the valve body. Make sure you haven't bent the rams that will cause this as well. If you have you will hear the hydraulics trying to over come this. Make sure the power is getting to the solenoid as well to make them click. Sometimes the switch inside the cab will break inside and not send the electric signal to the solenoid. inside when they do this they are moving a spool valve to redirect hydraulic flow of fluid to one ram or the other. Hope this helps :-)
Jan 24, 2015 | Cars & Trucks
How do I fix the plow pump it wont turn off?
I do not know that unit but it sounds like either a leak internal to the hydrulics or a bad pressure switch.
Dec 13, 2014 | Cars & Trucks
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
Fisher plow only turns right no matter which way you move joy stick
Oct 29, 2011 | 1999 Chevrolet K1500
I have bought a minute mount 3 plug plow. The lights have power and are on. I try to the joy stick and the power clicks off on the stick. I tried to lift and angle the plow when the power on the stick...
Sep 22, 2010 | Chevrolet 1500 Cars & Trucks
Wiring for western plow joystick
My western snow plow will not go up or left or right with joystick. I can use a screw driver and make contact on the silanoid and then move the cables with the joy stick and then it will work. I have relaced selinoid and contacts. any ideas? Stomped
Oct 25, 2009 | 1990 Chevrolet Crew Cab
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
