Question about Garden
I have power to joy stick when i move it to operate plow power light gos out and plow doesnt work
Trying to use plow power light comes on in joy stick. when trying to operate plow light goes out and no operation of plow
  • Tom SPITZ
    Tom SPITZ Dec 13, 2016
    solenoid does kick in
  • Tom SPITZ
    solenoid doesn't kick in
countrysi248
  • 443 Answers
SOURCE: no air coming through the vents
Sounds like the door that brings in fresh air is not closing enough so when you get to moving it is not letting the cab recirculate the inside air and bringing in some from the outside which comes from the bottom of the windshield on the outside. along with when you get to hitting the gas going down the road you might be loosing a little vacuum and that door going to your vents might close a little.. ? what you thinkin? just a few ideas might not be a fix though thanks Jerry
Posted on Apr 22, 2009
SOURCE: I have a Canon DC310 Camcorder and it will not
try finalizing while the cam is plugged to the charger not while it is operating on battery, it works with the DC210 i have.
Posted on Aug 18, 2009
  • 44 Answers
SOURCE: I have Aspire 5520-5912 Notebook. When I turn on
Sounds like you got a virus or may have been fitted with the wrong power adapter. Because of the complexity of laptop computers, I recommend having the geek squad at your local Bestbuy troubleshoot this matter.
You need a professional who can actually see what's going on to properly troubleshoot this issue. Geek Squad is the best of the pros, and my friend in technology.
Have them check to see that your harddrive is operating properly, and that your computer is not having internal power issues. If your laptop is still under warranty, often Geek Squad can honor a manufacturer warranty, saving you a lot of money.
Posted on Jun 30, 2010
  • 57 Answers
SOURCE: I have bought a minute mount 3 plug plow. The
It sounds like there is an in-line circuit breaker which is either defective, or not big enough or the motor is drawing too much amperage. Check with the manufacturer and ask the questions: what size circuit breaker should be used and what is the minimum wire size required. Check against what you actually have. You will probably find a wire hooked directly to the battery and the circuit breaker is usually located first in line close to the battery. Too small wire size could cause a fire.
Posted on Sep 22, 2010
wcdoc1953
  • 278 Answers
SOURCE: have a Pronto m91 power chair. Suddenly stopped
Sounds like you are on the right track with your problem solving. Unfortunately you cannot determine an electronic fault by visual inspection of the components. You can see cuts, nicks, broken wires and burnt components, but this only works sometimes.
I look at the current fault code with a hand held programmer (HHP). With a HHP you can read the fault log and check out all the stored codes to get an overall idea of the history of chair problems. The 7 flash code is definitely a remote fault. You can also get this fault with a bad connecting cable between the joystick (remote) and the controller (in the base). Check this connecting cable for breaks, cuts, loose pins or connections and check the connections at both ends. You can do continuity and component checks of the remote with a digital voltmeter, but this is out of the realm of most end users.
I am assuming you have MK5 or MK6 electronics in this discussion.
The easiest test is to swap out the joystick with a known good one that either a tech has brought to your home or you have brought the joystick in to a service center for testing. The better test is with a HHP that will give you the current problem and stored information of past problems.
Weak batteries or loose battery connections can also give a myriad of electronic faults. For this reason I always check the batteries and battery connections first.
The joystick can be rebuilt, but I recommend replacement as a more cost effective solution. I always replace the joystick to controller cable too. Labor charge for this work is under 1 hour.
I can provide further information if needed. Hope this helps.
Posted on Dec 03, 2010
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
Fisher plow gets power to lights but wont lift or turn, Any ideas?
Fisher needs a good contact loose contact start from the battery and work your way around everywhere theirs a connection
Dec 28, 2012 | Fisher Minute Mount Plow Joystick...
Fisher plow only turns right no matter which way you move joy stick
having the same problem just wondering if you figured it out??
Oct 29, 2011 | 1999 Chevrolet K1500
I have bought a minute mount 3 plug plow. The lights have power and are on. I try to the joy stick and the power clicks off on the stick. I tried to lift and angle the plow when the power on the stick...
Sep 22, 2010 | Chevrolet 1500 Cars & Trucks
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
May 24, 2010 | Jet 3 Ultra Power Chair
Wiring for western plow joystick
My western snow plow will not go up or left or right with joystick. I can use a screw driver and make contact on the silanoid and then move the cables with the joy stick and then it will work. I have relaced selinoid and contacts. any ideas? Stomped
Oct 25, 2009 | 1990 Chevrolet Crew Cab
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
