Question about Garden
Western plow power to joy stick when joy stick moved power light goes out nothing happens
  • 51 Answers
SOURCE: minute mount 2 fisher plow stopped working up down
there could be a flat spot in the motor that runs the blade
Posted on Mar 03, 2009
  • 832 Answers
SOURCE: western snow plow when you try to angle to right
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Posted on Dec 02, 2009
  • 177 Answers
SOURCE: no power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Posted on May 27, 2010
  • 57 Answers
SOURCE: I have bought a minute mount 3 plug plow. The
It sounds like there is an in-line circuit breaker which is either defective, or not big enough or the motor is drawing too much amperage. Check with the manufacturer and ask the questions: what size circuit breaker should be used and what is the minimum wire size required. Check against what you actually have. You will probably find a wire hooked directly to the battery and the circuit breaker is usually located first in line close to the battery. Too small wire size could cause a fire.
Posted on Sep 22, 2010
  • 146 Answers
SOURCE: I have a western unimount
88-to early 99 all models 1500 to 3500
Posted on Nov 17, 2010
Testimonial: "Thanks a lot for the answer. I've been shopping online for a truck and this is the most straight forward information I've seen for this question."
HOW TO GET WESTERN SNOW PLOW TO GO LEFT AND RIGHT
Hydraulic fluid doesn't really freeze. When it does, we wouldn't be around to see it. You need to go threw electrical. Go to there web site and see if you can get a diagram for it. Old systems are fairly easy to go threw. Newer ones have PC boards. Older ones, the stick/switches go bad first. But it always wise to loosen, then tighten the nuts that hold wires first. Corrosion sets in because it isn't used for so long.
Dec 18, 2016 | Cars & Trucks
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
Fisher plow only turns right no matter which way you move joy stick
having the same problem just wondering if you figured it out??
Oct 29, 2011 | 1999 Chevrolet K1500
I have bought a minute mount 3 plug plow. The lights have power and are on. I try to the joy stick and the power clicks off on the stick. I tried to lift and angle the plow when the power on the stick...
Sep 22, 2010 | Chevrolet 1500 Cars & Trucks
Wiring for western plow joystick
My western snow plow will not go up or left or right with joystick. I can use a screw driver and make contact on the silanoid and then move the cables with the joy stick and then it will work. I have relaced selinoid and contacts. any ideas? Stomped
Oct 25, 2009 | 1990 Chevrolet Crew Cab
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
