Question about GE Washing Machines
How to replace shattered lid on ge harmony profile washer?
    Top Expert:
  • GE Master
  • 8,204 Answers
Try and find replacement company on the internet or get in touch with a company that deals in washing machines.
if you put your details into google search might help you.
Posted on Dec 13, 2016
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
  • 146 Answers
SOURCE: HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Posted on Nov 09, 2007
  • 8220 Answers
SOURCE: GE Profile Washer won't drain
You might have a faulty lid switch mechanism or trash in the pump or both. MANUAL
Posted on Sep 09, 2009
  • 119 Answers
SOURCE: have a message on GE Profile Harmony washer that
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Posted on Jan 16, 2010
SOURCE: GE Profile WPRE6100G Top Load Washer how do you
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Posted on Dec 26, 2010
I need to replace the glass lid
This is the cheapest lid that I've found online:
I didn't find any part numbers for just the glass.
Good luck.
Aug 12, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
How do i remove the lid on a ge profile harmony washer?
Use a putty knife to remove the front panel first/
The putty knife will insert between thr top of the lid and the front panel about 2 inches in from each side.
The panel will pull forward then up to remove it.
Then remove the screws holding the lid down.
You may have to open the control console to remove the lid.
Apr 03, 2011 | GE Profile WPRE6100G Top Load Washer
Ge profile harmony- needs a new "brain" according to appliance repair man. how difficult is that to replace?
If he means timer its very easy.
Remove console and timer is behind control knob
If this was helpful please rate me.
Sep 11, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
I need a owners manual.
May 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Close the Lid problem on GE Profile Harmony
Kevin, the switch is magnetic operation. You will have to remove the top to get at it. Do this by removing the back panel. Inside the panel on the left side will be 4 harnesses. Disconnect them. Remove the pressure switch hose from the tub. Remove the ground wire. In back on each side of the top panel there will be 2 phillip screws, remove them. Now lift the top from behind and slide foward. The whole top comes off. The lid switch will be on the underside just in front of the dispensor. You can test the sensor by using a magnet. Just open the lid and place a magnet just in front of the dispensor on the left side. The washer should work with the lid up. Catriver
Nov 30, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
47 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
