How to get the latest Win 10 update from 10586 to 14393 with error "too low memory needs 8G"
Trying to update to current Win 10 OS from my pre-installed Win 10 bought with IRULU walknbook 10.1 32G quad core 2 in 1 hybrid bought in Feb 2016 on Amazon. I have extra memory 42G available on external drive. Cannot dump previous system restore point.
  • M Hinkson
    M Hinkson Dec 13, 2016
    I purchased the hybrid with Windows 10 already installed Now it seems to automatically update then later automatically dump unused files. I got a message from Windows that an update is available but I can't seem to manually update because I can't get rid of old software. It wants to add the new in addition to the old.
    How do I dump old stuff manually
    Top Expert:
  • Computers & ... Master
  • 74,999 Answers
To update to Win-10, the system requirements are:
  • The present O/S should be either Win-7 or Win-9 [Licenced version]
  • Minimum 2GHs processor.
  • Minimum 2 GB of Ram
  • Minimum 20GB of free hard disc space partition. (C - partition)
Otherwise, won't go. No need to try.
Posted on Dec 13, 2016
  • M Hinkson
    M Hinkson Dec 23, 2016
    Finally cleared enough space on the drive by removing almost every program and all files, documentation and photos, then cleaned the drive using Avast Clean Up app. That did the final trick. The download of Windows Update has started.
    New Friend:
  • 7 Answers
I get windows 10 *********** fro site it provide 100% working.
Posted on Dec 23, 2016
Testimonial: "Vanskeys is a suspicious site so no thank you"
I lost the dc adapter to my irulu expro x11. Unable to find the specific one. Would an adapter for the x1 or one that has several little plugs for it work?
There's 3 specs you need to match. First, there's the size of the plug. Next, there's the voltage. Then, there's the current. The voltage should be listed on the expro, along with the current required. The voltage should match, but the current for the adapter is the minimum you'll need. From the IRULU site, the charger is 5Volts DC and supplies 2 amps, so if your other charger supplies 2 Amps at 5 volts DC, it should work, if the tip fits. More than 2 amps will work. Less might not, or will charge it slower. The USB cable can also charge it, but usually takes a long time, and can not supply enough current for continuous operation, so the battery will drain in use. It can take half a day or more to charge it through USB on some models. The multi tip adapter can work if there is a tip that fits, but make sure you select the proper voltage, 5 volts, and watch the polarity, as the outer ring can usually be set for either positive or negative voltage. iRULU eXpro X1Plus 10 1 inch quad core tablet Android 5 1 Lollipop support...
Jan 26, 2017 | The Computers & Internet
How do I get windows to reinstall on my irulu walknbook if the battery died during the first install? All I see is walknbook screen and pop up saying what you see in photo
Tutorial written on November 19, 2015 This tutorial will explain in detail how to reset Windows Tablet IRULU Walknbook. IRULU Walknbook If you want to return to the IRULU Walknbook to its factory settings, you only need to follow a set of instructions that give you here. We will explain two methods to achieve make the Windows reset. As a first step and before the hard reset, you must have charged the battery in your tablet as a whole, this for a blackout occurs during the process that damages the Windows operating system that has Reset Windows Tablet IRULU Walknbook by menu When you access the menu of your Tablet IRULU Walknbook follow these steps to reset a Windows fast and efficient. Swipe the menu and touch Settings Now it Change PC settings Select Update and recovery, then Recovery Touch Remove everything and reinstall Windows, select Next Choose the option to delete the unit completely Tap Reset You will see your Tablet IRULU Walknbook restart and start the process (this may take several minutes) When finished you will have been completed to make reset Windows Tablet IRULU Walknbook Reset Windows Tablet IRULU Walknbook using your keyboard This Windows reset is also very effective, just about to connect your keyboard to your IRULU Walknbook to carry out the process. Tap the On / Off icon on the login screen. Press and hold the Shift key while pressing touch Restart A menu will appear on the screen, select: Troubleshooting Tap Reset your PC Your Tablet IRULU Walknbook reboot and see the logo screen, wait a moment On the Reset your PC screen, tap Next Select the option: Delete the unit completely Touch Reset and wait a few minutes That's all, if you've done it correctly, you've managed to reset Windows Tablet IRULU Walknbook.
Translated by google translate
Feb 17, 2016 | Computers & Internet
Why is everything so big on my 10.1 irulu? Customer Reviews: iRulu 10.1 inch Android ..., Inc.iRulu 10.1 inch Android 4.0 Touchscreen Tablet PC Support MID Google 3G WiFi .... I have had my share of Apples products, Ipad 1 and 2. and so has my Tech ... so I looked u the titles and added them myself) and the pages and everything on ..... I tend to use this sort of device plugged in anyways, so that's not a big deal for ... Customer Reviews: iRULU Walknbook 10.1 ..., Inc.iRULU Walknbook 10.1 Inch PC, 32GB Hybrid Laptop, 2-In-1 Tablet, Microsoft ...Update 6/6/15: The tablet has handled everything that i've thrown at it and runs ..... It's a little bigger than my previous tablet, but not so big that I feel like I'm ... : iRulu X1s 10.1" Quad Core Android Tablet
Feb 03, 2016 | Tablets & eReaders
Irulu Expro tablet. Where is the Bluetooth setting?
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 ...
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 Lollipop support Wifi OTG ... Bluetooth: 4.0 ... iRulu Google Android Capacitive Tablet PC(1) ... 1 Comments 0 or 0 people found the following review helpful .... Connect With Us.
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core Tablet 16GB ROM 10 points Capacitive IPS touch screen Bluetooth 4.2. $89.99 $179.99.
Irulu Tablet - Android Forums at
Dec 26, 2015 | Tablets & eReaders
Why doesn't it show the live preview from the camera?
Go to this link: and click downloads to download manuals and any software for your device. here is also the link from the download tab:
Sep 03, 2015 | Irulu U1s Phone -5 Inch QHD Quad-core Dual...
Where can i get disply of iRulu Unlocked 5.5 Inch Victory 1(V1) Android 4.4 Kitkat Quad Core Smartphone (White) w/White Earphone
Display? Do you mean you are wanting to replace the front screen of the phone, having cracked or scratched it?
This may not be practical, given the cost of the phone compared to the cost of repair. These phones do have a warranty. That tends to mean they have at least a 3rd party service department. If you found out where it is services, you might be able to directly contact them for a part, but it is not very likely. And installation of parts to a phone is a more involved process than it might appear. Newegg sells these phones currently.
Aug 26, 2015 | Android Cell Phones
How can i see videos on irulu tablet
You could try updating the app. Go to Google Play store click the magnifying glass to enter search. Type in YouTube and select it from the list. Click the green Update button.
Nov 27, 2014 | Irulu 9 inch Android Tablet PC, 4.2.2...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
