Question about Alps MD 5000 Thermal Printer
The curl motor is not working properly - Alps MD 5000 Thermal Printer
  • 83 Answers
In the printer properties panel, select the print on the backside option. This disables the anti-curl function.
Posted on Jun 08, 2010
How to fix grinding noise? When I close the clamp it still produces curl but makes a grinding noise. I am wondering if this is damaging the machine and how I can fix it.
hi sorry i don't understand what clamp and curl ? can you please give model number, grinding can be a bearing or the motor. usually the bearing in that. top loaders it can be the gearing on the base. as for clamp and curl i don't know what they mean?? pipe clamp ?
Jun 30, 2017 | Washing Machines
How do i get to watch grandslam of curling on tsn now
Curling - TSN
www.tsn.ca/curling
  1. Cached
  2. Similar
2017 Ford World Men's Curling Championship. Ford World Men's Curling Championship: Gold Medal - CAN 4, SWE 2. 3:01. Ford World Men's Curling ...
2016-17 Curling Broadcast Schedule - Article - TSN
www.tsn.ca/2016-17-curling-broadcast-schedule-1.593081
  1. Cached
Oct 26, 2016 - 2016-17 Curling Broadcast Schedule. David Murdoch, The Canadian Press. 2017 World Mixed Doubles Curling Championship (Lethbridge) ...
Curling - Sportsnet.ca
www.sportsnet.ca/curling/
  1. Cached
  2. Similar
... Courtney, Carruthers capture Canadian mixed doubles curling championship · Canada's Brad Gushue wins gold ... Pinty's Grand Slam of Curling on Sportsnet ...TV Schedule · ‎Canada's Homan wins gold at ... · ‎Pat Simmons returning to skip ...
Curling T.V. Guide - My Curling .com
www.mycurling.com/curlingontv/curlingontv.html
  1. Cached
  2. Similar
Sun Apr 2 @ 11 am Canada vs Russia (on TSN 1/3, Canada) ... April 11 to 16, 2017 Grand Slam - WestJet Players' Championship Toronto, ON, Canada Thu Apr ... grandslam of curling on tsn Google Search
Apr 14, 2017 | Watches
Why does my secret curl work properly as it doesnot curl
What model an brand is it? Cant help without that
Jan 29, 2015 | Secret Health & Beauty
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
How to get to drivers side window to repair it off track pontiac grand am 1999
First you have to remove the door panel .Once the panel off, unplug the window motor and use a volt meter on the plug that plugs into the motor.Push the up/down button and check whether you get about 12 volts, if you do then your motor needs to be replaced. If not then the problem the main control switch on the driver door. You have to remove the motor in order to get that window up.
Thank you !!
The vinyl welt or glass run channel is curled up in the track binding the window glass fron coming up. After it sits for a minute or two like you stated it works its way up a little more each time. The reason is the curled up welt (vinyl) has to takes sometime to work its way back out somewhat. Then it will go up a little more and quit and so on as you said. To fix this you can add a lubracant called dri slide which will work possibly only if your window is fully up at that time. You will need to saturate it between the glass and the run channel (welt) that is curling up causing it to bind. I would do both sides for good measures. If this does not work to greta all you can do is to replace the welt for the glass run channel.
Jun 15, 2010 | 1999 Pontiac Grand Prix
HP 3000n Laser Color Printer - Paper is curling up when it comes out of the printer. How do I stop that?
Make sure you've let the printer know what type paper you are using. In the print dialog on your PC, you must choose in the preferences area whether Plain, Photo, Glossy, Cardstock, Envelopes, etc. Such things control the pressure of the rollers in the fuser, as well as it temperature. Too hot will result in curled paper.
Also, make sure you are storing the paper properly prior to printing. It can't be too damp either, or it will curl.
Finally, if all else fails, your fuser may be overheating and need to be replaced. Hope not. If so, look for a rebuillt one online. Much cheaper than new. Good lick!
May 03, 2010 | HP LaserJet 3000n Printer
Anti-curl motor error
Yes.
On the Document/Quality tab, select "Print On Backside" in the Media Type box.
Apr 14, 2008 | Alps MD 5000 Thermal Printer
Fusing temperature control
1-if the paper is curling, first thing to do is try fresh new paper.
the one that is there probably has moisture.
2- is the fuser o.k. ? if the rollers are not in new condition they will curl the paper. make sure the bottom roller is shiny and smooth, it is supposed to have a clear plastic on it if it is gone or in bad shape, will give problems.
Dec 11, 2007 | Office Equipment & Supplies
Alps MD 5000 Thermal Printer Logo
142 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
