Question about Haier Refrigerators
My Haier compact refrigerator suddenly stopped cooling.i cleared ice buildup and returned power to it .waited 30 minutes and still not cooling.what can I check
  • 575 Answers
Check if the compressor fan motor is engaging. If the fan is not spinning then the coil will freeze up again. Also check that there is enough air movement around the fan for circulation. This is also try for the inside fan. Good luck
Posted on Dec 13, 2016
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Refrigerator/freezer stopped cooling/freezing yesterday. Lights are on inside and 8 hear the fan running in the freezer but no cold air. Tried powering off and also unplugging to see if it would reset...
possible failure of defrost mechanism causing ice to build up behind back of freezer preventing air flow into freezer and fridge. Try turning it off for enough time for ice to melt if cause.
if this is issue the repair man will need the ice half melted to be able to test the thermistor that senses the ice buildup.
Nov 06, 2017 | KitchenAid KSCS25FKSS Side by Side...
Ice buildup, not cooling well
The ice build up on the cooling coils prevents you fridge from cooling properly. You need to unplug it and allow the ice to melt. When the coils are free of ice, the fridge should work better. Hope this helps you.
Dec 17, 2010 | Sanyo SR-4910M Compact Refrigerator
The fridge is making a sound like a helicopter propeller -
Hi, The fan is hitting ice buildup... read these tips...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Samsung RS2630WW Side by Side Refrigerator
I have a Haier compact refrigerator (Model: HSP03WNWAWN-01, Serial Number: A205673063 - I defrost it and know it will not get cold. It comes on but will not get cold. I tried plugging in in for 24 hours...
Unplug the unit then turn the thermostat all the way on then all the way off, then slowly move from off to fully on position do you notice a spring popping sound at a certain point? Yes No? if yes turn it all the way off and wait ten minutes then plug back on, notice if the compressor comes on or not. If it does then turn the thermostat to half way on does it cool now? if yes you have the problem solved, if not you have an issue with the defrost circuit and you need tools to test it, if you have an ohm meter let me know and I will help you further. Thanks for using fix-ya
Jun 05, 2010 | Haier HSB03 Compact Refrigerator
GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Jul 26, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Haier HTQ21JSS - Freezer works fine but fridge won't cool
RFGirl, you didn't give me much...that said, try a full defrost of the unit. You probably have a buildup of ice caused by condensation. This is probably because the door seal isn't doing its job well. If the coils that do the cooling are not exposed, you must either wait for a full defrost...about 2 days or figure out how to remove the covering panels and go about melting the ice. If you do, be sure that any heating equipment...like a hair dryer...be kept from getting wet. If this happens again, you probably have low gas levels in the box...you'll need a tech. Be sure you unplug the box.
How to check for low gas: Once the unit is defrosted, start it up with the coil covers off...after about 5 minutes, you should see an even coat of frost at both ends of the coils. If not, wait 5 minutes more. If still not, you're low. Alternate method: Go round back and find the compressor...the big black thing. It has a couple of pipes sticking out. The largest is the suction line. Start the unit. Wait about 5 minutes. It will frost up. It should either get dry or form liquid condensate on it if you've got enough gas. If it stays frosted, you're low.
Hope this helps.
Nov 27, 2007 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
