Question about Frigidaire Dryers
My frigidaire affinity dryer model #Fare4044MW is stuck on pause
  • 172 Answers
SOURCE: error code E4A on my
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
My dryer wont start up, keeps going to "pause" on read out, affinity model farg4044mwo
Hey Jhnpoorman31, thank you for your post!
From the information you have provided your Frigidaire dryer will not start and continues to display "pause" on the panel. I see that you have replaced the door switch and still experience the same problem. This could be a potential issue within your control panel or wiring harness. I would recommend seeking help from a professional technician, this will help prevent you from any unnecessary part purchases. I hope this information is helpful towards your repair. -Matt
Mar 11, 2016 | Frigidaire Dryers
My dryer says pf and I just put the clothes in so what does this mean?
On some models pf indicates a power failure. Try unplugging and re-plugging after a short pause.
Aug 17, 2015 | Frigidaire AEQ7000EG Affinity Series...
When i try turn my frigidaire affinity dryer on it buzzes and goes to pause
Good Morning friend, thank you for your post!
From the information you have provided your Frigidaire dryer is buzzing and goes on pause when you attempt to turn it on. This could be a possible issue with your door latch, door strike, or control panel. If you dryer shows pause that means there is an interruption within your cycle. I would advise to look over your door latch and strike to see if there is any apparent damage to either component. If both components appear to be working properly I would advise to have a technician come out to review your control panel. I hope this information has been helpful to some degree. -Matt
Feb 17, 2015 | Frigidaire Dryers
Frigidaire electric dryer model FARE4044MW wont start it has a bunch of codes "RR AU U5 SE. I tried restarting unpluggin for 3-5 minutes but it did't change
Sounds like time to call a repairman. its probably a fuse but you wouldn't want to tackle it would be my guess. Have you got a user's manual?
www.sears.com > Appliances > Dryers > Electric Dryers
  • Rating: 4/5 ·
  • 21 reviews ·
  • 21 ratings ·
  • $699.99
User Manuals; Protection Agreements; ... Description Item # 02667202000PModel # FARE4044MW. ...
Jan 18, 2015 | Frigidaire Dryers
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
I have a frigidaire affinity dryer serial #xd72014132. It runs for a minute or so and then shuts off and displays e68. The buttons do not seem to be stuck and work properly. Any idea what is wrong with it?
I have a frigidaire affinity dryer serial #xd72014132. It runs for a minute or so and then shuts off and displays pauze. The buttons do not seem to be stuck and work properly. Any idea what is wrong with it?
Sep 20, 2013 | Frigidaire Dryers
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Affinity Washing Machine, 3 months old, pauses during cycle. Does not give any error code. Have tried different cycles, eventually it will run the cycle. Doesn't happen with every cycle, yet. Switches...
Did you figure out this problem? I think these machines are JUNK! We purchased our first Frigidaire Affinity in April 2010 & by September it started ripping our clothes apart. Not every cycle. At first we thought it was the dryer but nope - it was the washer. Something to do with the drum. We had it replaced in October 2010. Then after the truck dropped off the replacement, I tried doing my first load of laundry. It lite up & did nothing. Something to do with the motor. Again, we had a 3rd machine replacement. I wanted to give up, get my money back & go buy something else but I wanted it to match my dryer so I was kinda stuck. Our 3rd machine is now going to pause constantly during a cycle. I've read up on it & tried various things such as less soap, checking the drain etc. & nothing has changed this problem. I'm calling the store on Monday & demanding my money back & they can take back the dryer too. I have a feeling this might be a bit of a fight but I am disappointed with the results of this machine. We've lost about $100+ in clothing from the first machine, plus all the down time in all 3 of these machines not working & having to worry about going to do laundry elsewhere.
Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Dryers Logo
134 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
