Question about Hardware & Accessories
Where can i buy micromark MM9539 batch No.164021/0010 timer as one of mine as packed up i have had them for many years.
2 Suggested Answers
SOURCE: i need a micromark adaptor mm70029 for a led
visit www.eagalpower.co.uk they have them in stock
Posted on May 20, 2010
Can I set the Malibu 8100-0600-01 to operate at 2 different times at night-(ie- on at 7:00pm-off at 10:00pm then on again at 5:00am and off at 7:00 am)
Yes: Rotate power pack selector to ON. Buy analog wall timer with 3-prong plug from local store. Plug power pack into analog wall timer that will turn power pack on-off twice a night.
Copy following link to identify timer and also see tips for prolonging power pack life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Analog timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
The 1-year warranty digital transformers sold by Malibu and other vendors are made for single on-off events per each night.
If you manually set power pack to ON so lights are on all the time, then plug power pack into ordinary analog wall timer, then the analog timer turns power pack on-off when you want.
Other option is to buy 5-year warranty Intermatic-Malibu power pack with built-in analog timer dial and set trippers to turn on-off when you want. Order extra trippers for more on-off operations per each 24-hour day.
Gene
h
Aug 20, 2013 | Hardware & Accessories
Where can I buy timer pins?
1) Copy following link for Intermatic replacement trippers, and tips for longer lasting power pack, 5-year warranty, and troubleshoot.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
2) If this is not your timer, Add comment Feb 2013 and describe timer in detail.
Feb 07, 2013 | Malibu ML200RT - Low Voltage Power Pack...
My outdoor low voltage lighting is blinking on/off - cycles on/off every 2 seconds (approximately) - this is not an issue of the photo sensor picking up light from the installed lights. Colder than us
1) Most photocell timers have 1 year limited warranty, but unclear who carries warranty without knowing brand.
Do not buy expensive timers with photoeye unless purchased at local store where ez exchange can be made for several years.
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Buy Intermatic-Malibu power pack with 5 year limited warranty:
3) Set power pack to ON position (or override position) and then plug power pack into cheap 3-prong wall timer, for example timer with optional dawn-dusk or remote control sold at Lowes and Home Depot.
http://waterheatertimer.org/pdf/Woods-49554-TM16-manual.pdf
4) Add comment and describe timer in detail for more possible help
Dec 27, 2012 | Yamaha Xv 250 Virago S Motorcycles
The timer went out and the time of day no longer changes. I can manually turn the lights on by rotating the switch on top of the timer. How would I go about replacing the timer?
Question posted under Intermatic/Malibu power pack.
Timer clock modules are not sold separately for this timer.
Some people report being able to take the clock module apart, cleaning gears and re-lube with Vaseline. Mark parts carefully so re-assembly is easy.
Power packs have 1-5 year warranty.
Another work around is to buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
Open following link for troubleshoot steps, trippers, links to manuals, tips for next power pack, and warranty contact info.
Aug 10, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
Malibu Model: ML200TW Transformer Automatic timer not working
You can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
I wrote power pack troubleshoot checklist:
http://www.fixya.com/support/r8391011-power_pack_not_working
Jul 23, 2010 | Intermatic Malibu 300W Power Pack...
The timer stopped working
you need to pull apart gear housing - the final shaft has no bushing and seizes sometimes - take apart use emery cloth to remove corrosion and re-lube with heavy grease - good for a few more years - I've done mine several times now.
Jul 05, 2010 | Malibu ML200RT - Low Voltage Power Pack...
The timer is not working. Can I buy the timer unit seperately? The transformer works fine when I wire it to bypass the timer.
Yes you can I was actually about to purchase one myself. I left mine on it's side for a couple of years and the mud built up on the inside.
http://www.aplussupply.com/intermatic/timermotors.htm
Mar 26, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Hardware & Accessories Logo
46 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
