Lasko 5841 M
There are 3 red lights that came on, what do they mean?
I have a Tower Lasko heater and the red light came on and no heat??
pick it up and shake it. put it down and try it again.
Jan 02, 2018 | Lasko Heating & Cooling
Lasko heater blinks 88 no heat
What type of Lasko heater do you have?
Nov 12, 2017 | Televison & Video
LASKO 5624 will not turn on. The red light underneath the clock button is on. How do I reset? Is this broke after 20 uses?
Disconnect power, (unplug); wait for over 20 minutes, (have a cup of coffee); Depress power button before pluggging in to wall socket . (This will let any voltages that are stored in the unit drain off).
Plug in to AC outlet and press power to turn on.
If this doesn't work, Lasko has a 3 year warantee.
CUSTOMER SERVICE:
Toll-Free (800) 233-0268. Email: producthelp@laskoproducts.com
Feb 02, 2015 | Lasko 5624 1500 Watt Convection Heater w/...
How do I know which wires go where on a lasko tower fan, I'm trying to use the lasko motor on a blower
You have to cut the blue wire, WAIT NO, the red wire. No the blue wire, yes cut the blue wire. Phew that was close. (How the hell is anyone going to know the answer this question? you took the think apart so you can see what the wires are for)
Dec 03, 2014 | Lasko 48" Xtra Air Tower Fan with Air...
My lasko 5160 is flashing 88 with some other lights on,what do i do
At least for the Model 5165, the "88" means there is a circuit error -- probably applies to other models as well. First, call Lasko Customer Service 1-800-233-0268 (M-F, 8AM-5PM, EST). Have your receipt ready. Lasko will ask for a engraved number at the bottom of the heater, may have to look a few times to see it, normally about the serial number. Hope this helps!
Nov 16, 2010 | Lasko Heating & Cooling
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Lasko 5610 red caution light, no power
the caution light is telling you something is wrong. most wired baseboard heaters have a hi limit cutout that may be bad.  it is connected into the heater circuit as a safety device.  you could jump out this element to test this theory.  if the element is shorted, certainly it would blow a fuse or circuit breaker.  if the element is open it won't heat at all.  you need to take it apart and use a test meter to troubleshoot it.
Jan 02, 2007 | Lasko 5610 Baseboard Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
