Question about Kitchen Appliances - Others
Who to re move code 8 short freeze thin ice Scotsman ice machine
Sea Breeze
  • 4655 Answers
SOURCE: My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Posted on Apr 23, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
SOURCE: scotsman mv 450 ice machine harvest cycle is
Posted on Feb 22, 2010
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 7 Answers
SOURCE: scotsman icemachine m# DCE33A-1WB ice cubes are hollow
Have several of these machines here. The cube size control and the hot gas valve are common problems. I've had several that had one or the other. Generally if the cubes are forming and not harvesting the cube size control is likely the culprit. If no ice is forming then the hot gas valve may be leaking by or several of my machines have had leaks around this valve. The replacement part is not the same as the OEM part.
The charge is tricky and no access valves on this machine. Weighing in the charge is preferred.
Posted on Aug 23, 2010
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
Why does the the light blink on the red ice cube logo on the scotsman ice machine?
That means it is not freezing pull front cover and then you can reed the error code and if you will give me the code i can help you with it.
May 13, 2014 | Scotsman Kitchen Appliances - Others
Short freeze
Ice is to thin. Check to make sure water inlet valve is not letting water go through valve during freeze cycle. Make sure condenser coil is clean and condenser fan is running. Check the hot gas valve to make sure it is not bypassing during freeze cycle.
Apr 15, 2014 | Scotsman C0630MR_HD30B-32 684 lb 30"...
Code 8 blinking machine making very thin ice?
Short freeze, thine ice.
Cause: Grounded ice thickness sensor.
Solution: Check sensor for dirt and position. Clean and adjust gap to evaporator surface using 13/64" drill bit as a gauge, lay flat between evaporator plate and ice thickness probe and adjust 1/4 screw 1/8 of a turn clock wise at a time after every harvest cycle. You don't wont the ice any thicker than 13/64 or thinner either. If you are still having problem after cleaning probe then replace it but you will still have to adjust the probe.
Aug 08, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Mv 450 scotsman ice machine
Remove the front panel to the ice maker. There should be a control panel that will give you some more info on the fault. I am guessing that you are dealing with a short freeze cycle, thin ice, or harvest error.
May 13, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Fault Code 8 Short Freeze
Likely cause.
1. Grounded ice thickness sensor.
Solution, check sensor for dirt and position. Clean and check gap to evaporator surface.
Apr 18, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
My scotsman ice machine makes thin ice cubes
rotated the ice bridge adjustment screw clockwise about a 1/8 turn in between freeze cycles. thich direction makes the ice thicker.
Mar 27, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
There is usually a sensor that the cubes will touch after the cubes thickness builds to a certain point. This sensor should be adjustible.
Dec 04, 2012 | Scotsman C0330SA 1B 300 lb Cube Ice...
Kitchen Appliances - Others Logo
218 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
