How to check the power supply may "cause by wrong ac voltage .red light at power panel swift showing red. .I turned on click on rellay..like protect. .thanks I help to find schematics diag.
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/...
Posted on Dec 13, 2016
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: power up problem
i will need the model number of your set in order to help you with your problem. Please post the model number and I will try to help you out with the problem.
Posted on May 07, 2008
Coldcut
  • 1554 Answers
SOURCE: LG 42KK Power Supply Schematic Requested
you won't find any just ,
use a thermal probe or thermal gun as heat is likely the issue ,
if nothing else replace the main diode /rectifier and caps.
I find that if I replace the hottest items that usually the fix
if there is room for a small fan you will be doing them a great service and extend the life of the tv.
you may find some info on the power supply from one of these links they are generic enough
http://www.pacificdisplay.com/links.htm
Posted on Jun 10, 2008
Davetyke
  • 14 Answers
SOURCE: protron lcd tv getting no power
I can get a new replacement power supply for some internal power supply models. It's fairly easy to remove and replace. dave@thola.com
Posted on Mar 06, 2009
I have a Samsung 50 inch TV model 50B450B1DXZA. when I turn it on I get a flashing red light. I have replaced the power supply and X-main boards. they both have correct voltages on them with nothing e
Failure on one of the boards the power supply is servicing may be causing an over current relay to trip repeatedly.
Check PS voltages while the clicking is present to see if one of the outputs is unstable.
Dec 16, 2014 | Samsung Televison & Video
How do you to troubleshoot a Panasonic Vierra tc-P46G25 TV that does not turn on?
Check for bad capacitors (they'll look bloated) on the power supply board. Also check the voltages on the power supply board with your meter ; they should be etched on the board at test point location(s)
Jul 16, 2014 | Televison & Video
Panasonic Kuro pdp-5020 8 blinks of red led
Is power voltage going to the Panel screen?Can you measure that?
Check power supply voltage distrbuition line.
Nov 04, 2012 | Pioneer PDP-5020FD 50" 1080p KURO Flat...
We turned our tv off for like 3 hours went to turn back on and red light turned blue like it was going turn on but screen stayed black then speaker made a noise and light went back to red. It did that 28...
The problem is the power supply of your television.The power supply have abnormal voltage supply output cause of leaked capacitor.The leak capacitor have bulging tops, so that you can identify the leak capacitor. Just remove the cover and find the power supply and replace new capacitor with same polarity.Hope it will help you.Thanks..
Sep 04, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I have sony J21mn11. problem not power on only red lit led only.i check all the components on the power supply area and horiz. output D1878 all are good. there is power IC STR S6707 on power supply area. i...
If you have a digital tester or analog try to check the voltage reading from the power supply if high or low or no supply.Check first following voltage location and section. * Check the AC voltage from ac cord to fuse and before the bridge type diode. * Check the DC voltage after the bridge type diode.if normal voltage. * Then check the voltage into the filter capacitor to regulator ic.the power ic.If theres a input voltage in the power ic,check the output voltage going to harizontal output.If no output the problem is you power output.You need to replace it.
Jul 12, 2011 | Sony Televison & Video
The t.v powers on for just a second and clicks off. I can hear a click from the back and it recycles off/on over and over.
open the set remove all but the ac cord connectors from the power supply; label them first! turn on the tv if the power supply does not recycle turn off the set and, connect and, disconnect each cable one at a time going to the power supply turning the set on and, off each time as you test until the power supply cycles (fails) again then repair or, replace the circuit board that causes the power supply to fail. if the power supply cycles on and, off (fails) with all connectors but, the ac cord disconnected repair or, replace the power supply.
Jul 19, 2010 | LG 42PC3D 42 in. Plasma Television
The TV will not turn on. When I press the remote button or the TV button, it clicks like it will turn on, but the red light appears, not the green one.
Hello Peter sorry to say but your power supply board is faulty and needs to be replaced, the red light is indicating that your high voltage is out of sync or a component in the power supply circuit is causing this problem, call the manufacturer for the power supply circuit or let me know and i have a website where you can find the power supply, hope this helps thank you.
Aug 11, 2009 | iLO 3200 32 in. LCD Television
Dead KDLW40A12U
The TV develops a low voltage which a simple microprocessor uses to turn the power supply on when you use the remote or TV power button. Sometimes sets will show a red power light when the TV is in stand-by mode which turns green when it turns on. If you don't have that and don't hear a click when you first plug in the TV, you probably have a power supply problem. If you had a power surge, it could have blown the AC fuse. Try replacing it with the exact same rated fuse and you might get lucky. If it blows again, it will need service.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
