No background audio and no voice from the mic
    Top Expert:
  • Computers & ... Master
  • 25,306 Answers
Make, model and OS. You have installed the manufacturers drivers, NOT windows generic drivers!
Posted on Dec 13, 2016
Why do people say they can't hear me when I call them?
Well, there's a bunch of reasons why that could be:
•You speak in a muffled/slurred voice that is difficult to understand when the listener is not looking at you
•Your phone's microphone is defective and need repair/replacement
•you have a case on the 5c that covers one or both of the microphones. There are two mics on the 5c: one that actually captures the intended audio and the other there listens for background noise. What the phone sends to the listener on the other end is a subset of the two microphone sources passed through a complex filter.
The "main" mic is on the bottom of the iPhone while the background sensing mic is on the rear housing between the camera and flash.
•you have debris/dirt in the microphone holes
Aug 12, 2014 | Apple iPhone 5c
Audio buddy buzz
Background 50 or 60 Hz buzz can be radiated from nearby wiring or conducted. Grounding is important but that can also be a cause. I suggest you search accidental hum loops.
Poor or faulty power supply regulation or smoothing can inject a mains hum into audio. This would need checking with an oscilloscope which could also be used perhaps to help search for the source.
Radiated hum can be picked up and injected into high gain amplifier inputs and long leads, poor screening and impedance mismatch can make things much worse.
I haven't helped much but I hope I have given you food for thought and further research.
May 30, 2017 | M-Audio M Audio Audio Buddy Microphone
My acer aspire 4736Z webcam had a noise background
in control panel >> sound setting >> check wether mic boost is enabled or not if enabled then uncheck and disable the mic boost
Mar 02, 2010 | Acer Aspire 5610-4648 Notebook
HP laptops built in mic sound is messed up.
Check the windows audio settings from the bottom right , right click , select adjust audio properties , and make sure your microphone is set to it's highest levels , the screech can be caused by feedback so turning down your speakers may help with this. Skype also has audio configuration settings of their own , check the audio settings on skype and configure as required , doesn't sound like a hardware fault tbh
Feb 07, 2010 | Computers & Internet
About sound
your mic is muted... go into the control panel and then sound... add the mic in the settings ... then make sure it is not muted.
Feb 17, 2009 | M-Audio Computers & Internet
Microphone fuzzyness
control panel, mic, adjust background settings, this should do it.........if not let me know
Nov 24, 2008 | Computers & Internet
Headphones with mic model # na
Hello...
Try this one:
1.Click on Start
2.navigate to Control Panel
3.click on Sound, Speech and Audio Device
4.click on Sounds and Audio devices
another window will appear
click on the Voice tab
on the Voice Recording
click on Volume
there should appear another window
adjust the Mic Volume
hope this helps
Oct 09, 2008 | Computers & Internet
When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Oct 01, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
(sean.delcarmen@magicmic.com or customerservice @magicmic.com)
Dec 18, 2006 | Magic Sing Along Consumer Microphone
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
