Question about Vacuums
How to replace the handpiece cord
Electrical short in scaler handpiece cord
Kenmore Progressive Vacuum electrical issue. My
It could be the wires or switch in the hose and/or the connection between the hose and the vacuum. It could be the power cord or a loose or bad wire inside the canister. It could be the carbon brushes in the motor are worn out. To find a short or electrical problem you need to know how to trace the power flow from the plug and cord all the way to the motor. You can test the wiring in the hose with an electrical tester to see if there is a problem with it before you purchase a new one.
Mar 08, 2017 | Kenmore Vacuums
I need to replace electrial cord attached to machine myself
Make sure all electric is off strip off plastic covers on all parts of the cordes to be attached about 5incs easy to do with a razor slice on both sides or wire strippers then twist wires together and wrap with black electrical tape. Plug in and should have power
Jul 09, 2013 | Vacuums
Kirby cord has a short in it
cable overheated at bottom joint, blown wire internally, will have to replace cable. phone 0800 294 4692 for new cable 27.95
Jan 13, 2013 | Kirby Sentria 192006 Power Cord
My dyson will not turn on
make sure electrical out let has 120 volts, try another out let if all is good.electrical cord at the plug in prongs could have a short in cord.the control switch could be faulty and make sure vacuum bag and cannister in place tight.i remember some of 1960s and late model electrolux vacuum cleaner if the vacuum bag container door wont closed all the way vacuum cleaner wont turn on.
Jan 23, 2012 | Dyson DY500 Bagless Upright Cyclonic...
The lead on our machine is becoming frayed - is it possible to replace the lead and if so, how is it achieved? John Tuffley
If you are refering to the Electrical Power Cord? Yes, this can be easily replaced or repaired.
Depending upon where the cord is damaged, you can either cut it a little shorter and install a replacement electrical plug end (available at any electrical parts store (Lowes, Home Depot, Radio Shack, etc) for about $2.50.
Or if the cord is damaged near the vacuum, you can purchase another cord or even make up one yourself how ever long you want it within reason.
Jun 15, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Electric short
Remove the electrical cord and check the conituity for a short. If one replace the cord. If no short is found the motor is fried although the switch would have to be on when it smokes so I think you have a bad cord
May 11, 2010 | Sharp Twin Energy EC-7311 Bagged Canister...
Electrical short in handle
When you say there's a short in the handle, this can really be one of two things. It can either be the switch, or the cord.
Here's a link to repair that I did on how to replace the switch on your Dyson DC07:
http://www.fixya.com/support/t4576474-power_button_stay_down
And here's the repair that I did that shows you how to replace the cord on the Dyson:
http://www.fixya.com/support/t4560429-no_power_dyson_animal
This can really only be the two things that have an electrical short in the handle.
I hope this helped you,
Chris Jones
GoVacuum.com
Apr 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My friend has a Tristar MG1 vacuum. The cord was
Chances are that there is the tiniest fray of one of the wires touching somewhere. Since you have already made a good repair with nuts and tape, feel the length of the cord for other bite marks where a puncture might short the cords. If you find such a site, **** the sheath lengthwise, tape the wires and replace them in the sheath, then tape the sheath closed.
Regards, --W/D--
Aug 10, 2009 | Tristar Vacuums
The electrical cord has a short can it be cut and repaired
most of the time yes you could also try to put a new plug on the cord itself that could fix it otherwise i'd take it to a repair shop to have them change the cord for you sometimes it can be real difficult.
Sep 08, 2008 | Vacuums
Problem starting
This can happen if you have an intermittent short in your cord. Try plugging it in and then wiggling the cord around where it goes into the body of the vacuum with the switch set to "on." (If you're not sure whether it's on or off, just click it back and forth occasionally.)
If the motor kicks on there's a short, which usually requires a cord replacement. If that's the case, it's a relatively simple fix for most dyson models.
If not, you could have a short in your switch or somewhere else in the electrical system of the machine.
-R
Aug 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
