How to check the power supply./power start /with condition: red light show at power panel switch.
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Dec 13, 2016
4 Suggested Answers
  • 11800 Answers
SOURCE: hi, I have a Sony
The light turns red to signal the fact that the power source goes in protected mode - its safety system has detected a short on one of its outputs. So yes, it could be a problem with the power source itself - some of its filtering capacitors have aged and are now drawing a lot of current thru themselves. But it's much more likely that the problem is somewhere else - in your case the most probable fault is the Y-sus board, since the fault appears when it's time to start the plasma panel.
Posted on Oct 06, 2010
  • 4889 Answers
SOURCE: Visio p42hd, no picture
Yes it does sound like the mainboard. But we have to confirm. I will see if there is a service manual for this unit in my collection but do you think you can safely work on it? Have you worked on electronics before? The last thing I want is you hurting yourself trying to fix it. HV circuits are not to be messed with unless you know about them.
Posted on Nov 03, 2010
  • 19 Answers
SOURCE: My microwave oven doesn't give power supply when the power switch is on. What is causing this problem ?
Check the power outlet the microwave is connected to, as it might not be working. Try connecting a different device to it, if it doesnt turn on then the problem is from the outlet and you need to replace it. Otherwise, there could be a button which you need to press or sometimes you just need to close the microwave door for it to start working.
Posted on Jul 10, 2016
Why doesn't it turn on?
Modern Power supplies also monitor their load & other conditions and shut power off if a problem is detected.
Electrolytic Capacitors are the biggest problem.
Check for swollen or leaky Electro caps
Good Luck
How to Replace an Electrolytic Capacitor
Switched mode power supply
Feb 26, 2016 | Panasonic TC-P50X1 50 in. Plasma HDTV
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
Red light flashing
The red light is an error code indicating that A component in the TV is failing and is not receiving correct voltage, which is causing the TV to enter " protection mode" and show an error code. Could be any part of the TV but I would start with the power supply and go from there.
Usually the error codes are not very useful and you would need to count the flashes and check a service manual for you model.
Here is some basic info on testing the power supply.
TV Power supply general info
Jun 07, 2012 | Panasonic Televison & Video
Any bulged capacitors? If so- they caused the fuse to blow. If nothing is obviously showing fault, check the capacitors in the main portion of the power supply for shorted condition. Also look for failed resistors, and shorted TVS
Dec 20, 2011 | Televison & Video
When i switch on the tv it doesnt start there is just a little red light blinkin in front panel
Sounds like it could be a power supply problem I would check power supply for bad capacitors. look for bulging on the top of the caps and replace with same values.
Oct 06, 2010 | Panasonic 42" Plasma TV TH-42PY70 42 in
Blinking power light
The TV has developed a fault where the start up procedure cannot be carried out & therefore the TV switches itself back off. You would need to remove the back of the TV & check if there are voltages going to your backlights (24v), are there all the other voltage rails present at start up eg 15v, 5v etc. Check the power supply to see if any of the capacitors are showing signs of stress such as a bulging on the top. If you do not have a multi meter to check voltages or feel comfortable to do this, then it would be best to contact a repair service centre.
Aug 23, 2009 | LG 42PC5D Television
AKAI parts for a LCT3285TA and diagram of tv
If you know how to solder and de-solder you might be able to do it. Visually inspect the capacitors in the power supply circuitry for bulging conditions and replace the ones that shows that condition.
I service these power supplies, Let me know if you need further assistance.
Oct 27, 2008 | Akai LCT2785TA 27 in. LCD Television
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
