Question about Home Security
I just purchased an american security gun safe, serial El 255608 and it has no key pad or dial, only a phone cord hanging out of the front... how do i go about opening this thing?
SOURCE: unable to open digital safe
I have a similar problem as I have acquired (last night) a similar Woolies safe, locked, batteries dead & keys do not work. I am told you may be able to reset the code if you can depress the red button on the back of the door from the back of the safe through one of the bolt holes, easier said than done! Needs a stiff piece of wire or thin steel... good luck I will try this technique soon. These instructions were found by surfing the Net...
Posted on Apr 09, 2009
  • 80 Answers
SOURCE: Digital Electronic Security Safe S2120.
You will probably have to call a locksmith who specializes in digital safes, or you can contact hardline and give them the serial no. of the save and proof of purchase to get the code or key. You will probably need proof of purchase for the locksmith to.
Posted on Sep 19, 2009
rsmith972278
  • 160 Answers
SOURCE: I can't reset by keypad on my cannon gun safe electronic key pad
First I would try the original numbers to see if you did change it. If the original numbers work then you need to start over. If they don't work then the new numbers you installed are there and you need to figure out what you punched in not what you meant to punch in.
Hope this Helps,
RSMITH972278
P.S. FOR FURTHER ASSISTANCE PLEASE PROVIDE MAKE AND MODEL
P.P.S. PLEASE RATE ME
Posted on Nov 24, 2009
Obertelli
  • 3006 Answers
SOURCE: i have a american eagle safe by cannon with the
Call a locksmith out; there is absolutely no way to solve this remotely on the web, and even if there was it would be foolish to tell every thief on the planet how to defeat your model of safe.
Also, with respect, I don't know who you are. Imagine if your safe was stolen and all the thief had to do was to post an online question to find out how to get into it...
Posted on Feb 26, 2010
loxmith
  • 21 Answers
SOURCE: Safe SENTRY S3877 can not open the door
here is the number for customer service, 800-828-1438
Posted on Jul 24, 2010
GETTING IN A SAFE
You really have no choice but to break in or call a locksmith.
Sep 23, 2016 | Liberty FatBoy Jr. LFJ48 48-Gun Safe,...
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
Replace elctronic key pad fr tumbler lock
Unfortunately most safes cannot be converted from an electronic keypad to a dial lock. Those that can be are specific to the type of lock i.e. type 1, type 2 etcetera. I had the same problem with my safe where the keypad would accept the code but not open the lock so I had to use the key. I contacted the manufacturer and found that the circuit board was faulty and they sent me a new improved version for free. Your safe has a five year warranty and even if the warranty has expired I would contact First Alert to see if they can remedy your dilemma. They would also be able to advise you if your keypad can be converted to a dial lock. If it can be converted I would recommend having it installed by a certified locksmith that guarantees their work.
Apr 08, 2014 | FIRST Alert 2754DB Executive Fireproof Gun...
No juice no entry keys lost is there another way to get into a micromark electronic safe?
If you lose you keys, you will need to order duplicate keys from the manufacturer. They will need the serial number and model number of your safe and proof of purchase. After establishing the authenticity of the buyer, they will supply fresh keys at a nominal charge. The duplicate keys are specially ordered from the factory and takes 2-4 weeks for delivery.
However, for security reasons, if you lose your keys, we recommend to change the lock of the safe instead of supplying duplicate keys.
Feb 28, 2011 | Safe International Digital Electronic Safe...
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
Dec 01, 2010 | Safe International SentrySafe Home/Office...
How can I set speed dial if my phone is not the main telephone
If you have a USB port on the side of the cabinet, you can program it from the maintenance console. You can also program "personal" speed dial number in the 12 feature buttons on the right side of the phone, and/or under the dial pad on certain systems. To program the buttons, press PROGRAM the button and dial the number with an access code in front (usually 9) then STORE. So, to call 555-1212 you'd dial 9555-1212 STORE. and pick up the handset and drop it back down to end programming.
If you figure out how to program numbers under the dial pad buttons 1-0 keep in mind that it overwrites the F1-F10 keys.
Carl
Sep 15, 2010 | Panasonic KX-T7730 Corded Phone
How do you install a r front wheel bearing on a 2003 olds alero
Safely support the vehicle and remove the wheel. Unbolt the brake caliper and pad bracket. Leave the brake line connected and hang it off to the side (don't hang it from the brake hose). Remove the brake rotor and the axle nut (should be a 36mm. If your not using an impact gun, this should be removed with the wheel on if possible to stop it from spinning). Disconnect the wheel speed sensor and remove the three bolts securing the wheel bearing. The bearing could then be removed. It may require some persuasion with a hammer. Installation is reverse of removal.
May 09, 2010 | 2003 Oldsmobile Alero
We have a DKT3020 phone system. How do you set
You can go to any display phone:
For the date
1. press intercom
2. dial #651
3. enter yymmdd example ~ 091005
4. press the # key.
5. hang up
For the time
1. press intercom
2. dial #652
3. enter HHMMSS example ~ 170800 in military time.
4. press the # key.
5. hang up
Sep 25, 2009 | Toshiba DKT-2020 Corded Phone
Home Security Logo
52 people viewed this question
Top Home Security Experts
Are you a Home Security Expert? Answer questions, earn points and help others
