Question about Miscellaneous
82c341158821797 LCD panel - Miscellaneous
Is it worth to replace the LCD panel ?\ The Replacement LCD panel code is BN95-00604A How to do the LCD panel repleacment
Considering the price of a TV I'd say not.
Did a google search and found this site using BN95-00604A: http://www.encompassparts.com/item/9186449/SAMSUNG/BN95-00604A/PRODUCT_LCD-AMLCD where they list the part at 565.00 including a 102 core charge which I presume would be returned to you once the core is received. It is unknown if this source is the only source, that this source would actually sell the part to anyone other than authorized service providers, it also doesn't address shipping costs or taxes and damages that may occur in transit. Also from this site, I learned that this part is used in a Samsung UN40ES6100FXZA 40-Inch Led 6100 Series Smart Tv
Here it is on Amazon for 829 with free shipping: http://www.amazon.com/Samsung-UN40ES6100-40-Inch-1080p-Black/dp/B0076M04QU
Samsung UN40ES6100 40 Inch 1080p 120 CMR Slim LED HDTV Black 2012 Model
Apr 28, 2014 | Samsung UN40ES6100 40 Inch 1080p Smart TV...
NEC 40 in. LCD TV
You will first need to identify the LCD panel model # to your set. There should be a sticker on the back of the LCD panel assembly stating the panel model #.You will have to take the back cover off to expose the back of the LCD assembly. Do not make the mistake in ordering a replacement panel based off of your TV model # alone !!! Many TV manufacturers will use multiple panels in the same model series. Once you have your LCD panel model #, you can try Ebay or just google the LCD panel model #. If there are parts dealers with the panel, google should find them for you. Hope this helps
Sep 03, 2012 | NEC 40 in. LCD TV
Power indicater blinks 6 times
"Backlight Error" and the possible location listed is "LCD Panel"
The "LCD Panel" includes the "Inverter MT board" and the "TCON control MT board". The part numbers depend on the serial number of your KDL32BX300. Only one of the inverter boards is available separate from the "LCD Panel". One of the "LCD Panel" assemblies is available for a cost of $518.45. If the serial number of your TV begins with a 5, you are in luck if you would like to replace the "LCD Panel".
Jul 04, 2012 | Sony Televison & Video
I have samsung lcd LN52A550P3FXZA There is 1 blacks vertical lines on the screen i thinking to replace the LCD Controlleror Buffer Upper left
If this tv LCD screen panel have not cause by any person or object truma to LCD screen panel. This problems it is alway the causes of the T-Con decoders board sit in the middle bottom of the LCD screen panel.If it is causes by a person or an object causes truma to it,this LCD screen panel is radiations are dead for that area,this LCD screen panel can't be fixed.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Feb 17, 2011 | Samsung LN52A530 LCD TV
I have a sharp 42" lcd hdtv & the right half of the scren is black but i can still see some green highlights. any suggestions?
This tv the LCD screen panel it shorted and dead.This tv can't be repair,only replaced the LCD screen panel.Not,worth replacing the LCD screen panel,because LCD screen panels are limited produced by the tvs industries and will cost same as a new tv,if the LCD screen panel require replacing.Sorry the tv now,only worth as a salvage tv electronic boards for parts only now.
Oct 14, 2010 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
Needs a new screen, where do i take it in Minnesota thanks, Jeanne
LCD Screen panel is broken or damage,the tv not worth repairing,because the tvs Corporations produce these LCD Screen panels,are very limited in production of these LCD Screen panels.No where else u will able to buy a LCD screen panel,except the the tvs corporations themselves,yes they well sell the LCD Screen panel to u,but it well cost the same as a new tv.Might even cost more after labors of the installation of the LCD screen panel.Sorry the tv is not worth as a whole tv anymore,now only can be salvage for the electronic's boards for board parts that it.
May 24, 2010 | Vizio GV42L 42 in. LCD Television
Was told need new lcd panel for insignia 42 inch lcd tv
buy lcd panel for insignia 42 inch lcd tv
er~
you can visit the :http://www.udtek.com/lcd-panel-c-9.html
hope it can give your some help
Feb 25, 2010 | Insignia NS-L322Q-10A LCD TV
PROBLEM; TOSHIBA 40XF355D THIN RED VERTICAL LINES APPEARING ON SCREEN. ANY SOLUTIONS PLEASE?
There are 1 of 2 possibilities for this. The board mounted to the back of the LCD panel at the top of it is call the t-con board if that partially fails you will get the red lines in the picture. The other possibility is the LCD panel itself. Best to have a technician look at the TV to verify which one it is. In some cases the t-con board is not available by itself and at that point the LCD panel has to be replaced. If the TV is out of warranty you will spend less on replacing the TV if the LCD panel needs to be replaced as they run upwards of $2000.00 dollars.
Nov 12, 2009 | Televison & Video
Ghosting and very dark mostly orange screen
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Oct 05, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
