Wont let me change source - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
If so; do not try to change it. it is best.
Posted on Dec 13, 2016
Toshiba smart tv stuck on one channel tried new remote wont change channel went back to old remote still the same
Did you try changing the source? It might be getting the channel from a source other than the TV.
Sep 09, 2016 | Toshiba Televison & Video
My vizio smart tv wont work with my playstation 3 its keeps saying retriving data but then it says no signal what i am i doing wrong
mmmm, i don't have one of those tv's, but here's a guess. try find the automatic search for source option.
if that didn't work your ps3 is probably sat to HDMI or SCART, to change this: turn off your ps3 and hold the powerbutton when your turning it on. this will cause the ps3 to change between HDMI and scart, thats probably why it wont find a source.
Oct 12, 2013 | Televison & Video
I changed crankshaft and camshaft senors also ignition coil but wont start
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:3
Aug 11, 2011 | 1998 Dodge Neon
I hook up my ps3 and it wont come throu it says ( please change source resolution ) i tyed eveything i know it just wont give me a pic.
My brother had this problem too I think it happen when u have been using the pa3 with a non hd tv and then switch to a hd tv, try hooking it up to a normal (older) tv to change the resolution to sd (standard definition) then hook it back up to a hd tv and it should put up a message saying it's detected a hd source and prompts u to change it. Hope this helps mate Bogsy
Feb 23, 2011 | Televison & Video
Once watching a dvd it wont let me change the surround that i want. How do i fix it?
Apparently, the use of the built-in DVD player doesn't allow sound field manipulation; but external sources can be modified. This subject is only discussed in this section of the manual...
"Enjoying audio form an external
source
You can enjoy audio form an external source through
your unit.
Press INPUT repeatedly to select the desired input
source. - AUX, AUX OPT, AUDIO IN
Setting the surround mode
You can select the Dolby Pro Logic II. Press
SURROUND to change surround mode repeatly...."
Mar 15, 2010 | JVC TH-G30 Theater System
The airflow wont change when i select face, feet, or windscreen
you have a vacuum problem . could be a leaky hose or broken vacuum line.
these flaps are controlled by vacuum from your engine. check the black hose from the canister in the engine compartment that goes to your firewall near your evaporator coil. this is the supply vaccum line going to the switch. if you don't have a vacuum source here, then trace the source.
tnx 4 using fixya,
drcool
Oct 11, 2008 | 1996 Ford Explorer
Televison & Video Logo
Top Televison & Video Experts
