Question about Cell Phones
My iphone keyboard doent work - Cell Phones
Is there a button to turn on wi-fi using an external keyboard that doent havr the Fn key??
If the keyboard on your netbook has a button, then use the same button on your external keyboard. That should work.
Aug 15, 2012 | Coby NBPC1023XPBLK Netbook PC
My iPhone 4 (4.1) doesnt get connect with Mobile Wireless Keyboard? (Mexico)
It looks like the type of keyboard and mouse you are using is not bluetooth. You can't use the iphone 4 with just a wireless keyboard. It has to be a BLUETOOTH keyboard.
The Keyboard/Mouse combo you have from verbatim is most likely using Radio Frequency (RF) like the same frequency a TV remote control would use. Bluetooth is a different type of wireless technology that has to be paired with your iphone for it to work.
Mar 16, 2011 | Verbatim Keyboard,Wireless,Multimedia,With...
The pointer on my wireless mouse is not working. I just changed the batteries.
use the mouse near the comp.the range of the mouse from its sensor matters.if it still doent work try using the mouse on a different surface
Feb 09, 2011 | Toshiba Wireless Mouse PA3205U-1ETC
My compaq pasario keyboard stops working ...I reboot it works for a time I go back to it .. it's not working again .. reboot works then stops again
You first need to try and isolate the problem. Try using a USB keyboard. If you plug a USB keyboard into the laptop and it works with out a problem you need a new keypad. If the USB still is problematic than you may need to do a repair install of windows ( this can be done without changing your files or settings) If that doent solve the problem than its a motherboard issue.
Nov 15, 2009 | Compaq Keyboard
No keyboard on iphone when Im in gmail
I had the same issue and called Apple iPhone support. To fix it, I had to turn off my iPhone for a minute (like completely off where you slide it to power off rather than dimming it). Then when I reloaded it back up and opened my Gmail, it worked just fine. I know it seems like a simple fix but it worked for me so hopefully it helps you guys too!
Oct 24, 2009 | Apple iPhone Smartphone
It doent power on completly all it does is say itunes the menu wont pop up omly thing that pops up is the thing that says itunes
Open iTunes, unplug your iPhone
Turn your iPhone off.
Plug it in.
As soon as it starts to turn on, hold power and home for 10 seconds
Then release power but keep holding home for up to about 30 seconds, or until iTunes says it's detected your iPhone in recovery mode
Press restore.
Oct 01, 2009 | Apple iPod touch
The mouse doent work and i've tried evething in the instructions
is it a usb mouse or ps3 if usb get an adapter and try that
Jul 18, 2009 | HP Wireless Optical Mouse
My usb ports have stopped working
well you must first go to the device manager and check the port option if the port ikon doent appears then the drivers are not installed.In such case youhave to install the driver from the site.
Jul 04, 2009 | Apevia Laptop Keyboard for Acer Aspire...
Iphone bottom keys of keyboard don't work
ususally it's a dead strip on the iphone screen and it needs to be replaced. there is an iphone repair manual that will guide you through the steps the part is readily available on ebay.
Apr 27, 2009 | Apple iPhone Smartphone
Keyboard doent work very well
You'll need to replace the keyboard.
Ebay will probably be the cheapest place to get one.
If you're uncomfortable installing it yourself, find someone on craigslist or a local repair shop to do it.
Should only take them 5-10 minutes to do so don't let them charge you an arm and a leg to do it.
Best of luck!
Feb 26, 2009 | ASUS F5RL-X1 Notebook
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
