I bought my senseo philips HD7825. I loaded the water then plugged it in then I added the coffee pod. However, the power light kept blinking (slowly) as though it is heating up. But it is not heating.
Hi
Quite possible the boiler has failed. You would need to disassemble to check (with a multimeter) if the boiler heater elements are a continuous track from one terminal to the other. Boilers often fail - else you have a electronics problem somewhere that will require a tech person check out.
The other thing boilers can do is to develop an earth leak between the heater element itself and the outside of the element - this will cause the machine to shut down your house's power supply if you have an Earth Leakage Safety Switch installed in your meter box.
Given this was an inexpensive machine and uses rather "odd bod" pods it may be time to consider something more 'common' like a Nespresso, Aldi or the Cafitaly style of capsules.
I especially like the Cafitaly capsules as they have more coffee than Nespresso, have 2 internal filters, can be refilled with ground coffee (I reseal top with wide cellotape) and can be refilled at least 4-6 times before they should be thrown away. Instead of around 30-50c a cup, refilled capsules costs me about 9c a cup - I get about 100 capsules out of 1Kg (2.2 pounds) of coffee.... beat that.
Cheers
Mike
