How to adjust channel to correspond with number
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
Mar 29, 2011 | Uniden BC898T Base Scanner
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
What channel do you use for a DVD player? It won't "see" any channels that doesn't have a program on it.
If your dvd player has 3 plugs red white and yellow plug them into the slots marked av. the colors will correspond with whats on your tv inputs. then turn the tv to the av setting according to the av number you have the plugs in either av1 or av2 you should now see dvd player logo.
Jan 06, 2010 | Emerson CR202EM9 TV
I can't get the 2 way radios on the same channel
Press the Menu button. The channel number will flash. Press the adjust keys to select the channel number. Press the menu key again and the Subchannel number will flash. Set to desired number. Then press the push-to-talk key to get out of menu mode. Repeat with second radio and be sure to choose the same channel and subchannel. Then adjust volumne as needed.
have fun!
Nov 19, 2009 | Midland LXT310 2-Way Radio
Favs used to be on screen but since machine has been reset they've gone!! HELP!!
your gonna have to use the remote to solve this problem. you can press the open the menu by pressing it on the remote which will come out of your screen. toggle down until you find fave. channels. there are numbers which will be displayed which are the channels. all you have to do is to press enter for every channel you like then a number will correspond. for example, you want channel 9999, it will correspond to fave. channel 1 and so on. then go to the channel by pressing fav. or favorite on the remote then pressing 1 or a specific assigned number to the fav. channel.
Jul 08, 2009 | Televison & Video
All channels are locked out on Radio Shack pro 164. How do I unlock?
You banks you want to scan are not enabled press the number that corresponds to you banks to turn them on...
May 09, 2009 | Radio Shack Pro-97 Handheld Scanner
I wanna some information about electronic rolls in car
An electronic roll-a-long switch for use in a seismic exploration system and method of seismic exploration are disclosed. For a group of N sequentially numbered receiver points, N/2 input channels are provided. Each input channel receives input from one of two receiver points which are spaced N/2 receiver points apart. The input channels are multiplexed to a data bus in an order corresponding to the sequential numbers of the receiver points comprising the input channels. :D
It quit scanning stay on one channel
You probably locked out all the banks. Look at the top of the display, you should see numbers from 1 to 10. If you don't, press 'scan', then press each key that corresponds to any missing numbers (I'm guessing that all but the number '1' are missing). As you press each key the number will reappear at the top of the display.
Jun 11, 2008 | Uniden BC895XLT Base Scanner
No picture but there was a sound
1.service mode before putting unit into the service mode, check that customer adjustments are in the normal mode. use the reset function in the video adjust menu to ensure customer controls are in thier proper(reset)position. 2.service number selection once in the service mode, press the channel up or channel down button on the remote transmitter or at the set . the service adjustment number will vary in increments of one,from "S01"~"S19" to "M05". select the item you wish to adjust. number selection press the volume up or down button to adjust the data number. to enter the service mode. while pressing the vol-up and ch-up buttons at once, plug the ac cord into the wall socket and switch on the main power. now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
Sep 19, 2007 | Sharp 27J-S100 TV
Televison & Video Logo
Top Televison & Video Experts
