Question about Measuring Tools & Sensors
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
    Top Expert:
  • 36,498 Answers
Replacement has to be done in a certain order.
  • Remove all batteries
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Posted on Dec 13, 2016
My WS9620 does no show me the outside readings.batteries are new & the outside unit shows the temp. &the humidity
remove all batteries, bring the two units together and put the batteries in the base unit first, then the outdoor unit; they should sync within 2-3 minutes. Once they have exchanged temp and humidity once, you can separate them. Good luck.
May 02, 2017 | Measuring Tools & Sensors
Subzero Model 424 Service Light ON - Codes: 10EC, 15EC, 73UE, 73LE, 73UP, 73LO. No codes are EE.
an "EE" code means you have an open thermistor. "EC" is a extended compressor run code. typically with the 424 if the thermistors are good, as in no "EE" codes you probably have a refrigerant leak. 73UE is the temperature at the upper evaporator thermistor. 73LE is the temp at the lower evaporator thermistor, 73up is the upper compartment temp and 73lo is the lower compartment temp. the unit probably has a leak in the evaporator/heat exchanger assemblies and needs a refrigeraton system rebuild
Feb 28, 2013 | Sub-Zero Refrigerators
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
E"E" reading
From what i have seen EE means overload warning, I looked on the website your scale has a lifetime warrenty on it i would recomend calling customer service @ For Customer Service: 800-289-0944 before messing around with anything.
Apr 15, 2009 | Taylor 5743 BIA Body Fat Scale
I keep getting EE no matter what I do.
PLEASE make sure that your monitor is over your artery, there should be a small plastic part that will tell you that that is where it need to hit your artery for the EE to go away. IF that does not work, and I am sure it will, but I have heard, never even experienced it, but have heard that a LOW battery can trigger it, but again, in 15 years, never heard of it..... Guy... OH, let me know if you need any more help, glad to be here for you...
Apr 07, 2009 | Mabis HealthSmart Digital Blood Pressure...
Error code EE
I think it has something to do with the temp sense circuit of the control board, my fedders ac model a6d24e7a-e says the same thing if i bypass the temp sensing bulb with a resistor the unit will run but i do not have any way of controlling the temp, if i can find out that type of thermistor is being used i might be able to put a new one in and i will post it here
Jul 06, 2008 | Heating & Cooling
Maytag error message EE
What is the name and model number of your unit?
Jun 10, 2008 | Maytag M6Q10F2A Air Conditioner
EE IN TEMP DISPLAY
I just called a maytag repair store, and they just had one in the shop, it sounds like the control panel has died, and will need to be replaced. They cost around 60 dollars, + install fee.
Jul 05, 2007 | Maytag M6Q10F2A Air Conditioner
Measuring Tools & Sensors Logo
241 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
